New CORSAIR Dominator Platinum Kit Has Different Spreaders
Postby Apoptosis » Fri May 31, 2013 12:48 pm
I opened up a set of CORSAIR Dominator Platinum 2133MHz memory modules the other day and just noticed something about them. The silver tops on the modules heat spreaders are different. They looked off in the system and sure enough they are totally different. Once is machined and the other appears to be cast. The depth of the font and the font itself is also different between the modules in the same kit. The real kicker is the screws heads are different. It looks like Corsair is sourcing their parts from more than one company and are just mixing and matching them on the assembly line (one module had rounded heads and the other are more square).
Someone over at Corsair better step up the quality control as when you pay $100-$250 for a dual-channel memory kit you expect them to have the same look! ](*,)
Check out the letter R in the image below to see the font difference.
If you click on the image you can see how the top module has more of a shine to the surface and you can see the machine swirl marks from what looks to be a CNC machine.
Re: New CORSAIR Dominator Platinum Kit Has Different Spreade
Postby Apoptosis » Fri May 31, 2013 1:10 pm
Got a quick response from Corsair:
They did a changeover last year to the bottom style. Must have been an older style spreader in parts inventory and they didn’t notice during assembly. I sent the PM and VP so they can get the plant to screen for old style spreaders.
We’ll swap them if anyone runs into this problem.
So, if you have a pair of Dominator Platinum modules with different heat spreaders shoot Corsair tech support an e-mails!
Return to “Memory Forum”
Who is online
