VGA to DVD Player!
DJ Tucker
VGA to DVD Player!
Postby DJ Tucker » Thu Jul 10, 2014 10:54 am
I want to get my old dvd player to work with my old 17" LCD monitor without spending a fortune. I know a straight forward vga to scart or rca cable won't do it due to interlacing. So, I need to get a convertor but have no idea what convertor I would need to get my dvd player to output audio and video. anyone have any idea here?
Annihilator V3.0
Processor: Intel Core i7 2600k @ 4.8Ghz (1.376v) LEPA Exllusion 240 Mod
Hard Drive: SanDisk X110 128Gb OS Sandisk X210 1Tb Gaming
Video Card: Inno3d GTX 1070 Accelero Hybrid S 2100/9000
Monitor: AOC G2460VQ6
Motherboard: ASRock Extreme 6 Z77
Case: Vector Custom VDM01 with Corsair HX1000i PSU
Peripherals: Corsair K70 Lux, Corsair M65 Pro and Corsair Void Pro
bubba
Staff Writer
Staff Writer
Re: VGA to DVD Player!
Postby bubba » Thu Jul 10, 2014 11:28 am
Sounds like you need an old VGA Video Converter they used for game consoles...
something like this
http://www.amazon.com/gp/product/B003VJ ... 3OMIT2KMFQ
-Thomas Jefferson
KnightRid
Postby KnightRid » Fri Jul 11, 2014 4:28 am
I take it the only connection on your lcd is a VGA? If so then Bubba has you covered. Just remember you will probably have to hook audio up separate as VGA does not include audio signals.
Use the best connection you can! HDMI is of course first, then component, then s-video and finally composite.
My suggestion would be to save the money for the convertor to go to vga and look around for a dirt cheap 17-19" monitor with hdmi. For that small of a monitor and with only using it for regular dvd, you would not even need 720p resolution but most I think will have at least that.
DJ Tucker
Postby DJ Tucker » Fri Jul 11, 2014 12:34 pm
well that's exactly what I needed. got a convertor today and all works perfectly. the res goes up to 1280x1024 which is my res for that 17". the quality isn't as good as my pc of course but certainly fine for watching dvds in bed with the misses as she likes to fall asleep to them :)
Annihilator V3.0
Return to “OFF Topic (ie: nothing about computers)”
Who is online
Users browsing this forum: No registered users and 5 guests
