C1E and EIST?
DJ Tucker
C1E and EIST?
Postby DJ Tucker » Mon Feb 02, 2015 11:37 am
I have both of these enabled to reduce cpu usage while browsing and watching dvds. however some games I play don't use a lot of cpu and EIST makes my cpu jump all over the place and causes lag. disabling it leaving C1E enabled is pointless as my cpu keeps switching from idle to (multi 16) to load (multi 44). Is there a way that I can make my cpu stay at a multi of 16 until a certain load like 25% or above is required that will then kick in to a multi of 44?
Annihilator V3.0
Processor: Intel Core i7 2600k @ 5.0Ghz @ 1.416v With LEPA Exllusion 240 Mod
Hard Drive: SanDisk X110 128Gb OS Sandisk X210 512Gb Gaming
Video Card: Inno3d GTX 1070 Accelero Hybrid S 2100/9000 @ 1.063v
Monitor: AOC G2460VQ6
Motherboard: ASRock Extreme 6 Z77
Case: Lian Li DK-Q2X with Corsair HX1000i PSU
Peripherals: Corsair K70 Lux and Corsair M65 Pro
KnightRid
Re: C1E and EIST?
Postby KnightRid » Tue Feb 03, 2015 5:39 am
Nope - as far as I know and my knowledge is limited so if there is hopefully someone will chime in.
I never used these settings in any system I have built. I always turned them off as they only seem to be worthwhile if you dont do a lot on a computer, especially game. If you overclock they should be off anyway (in my experience).
Do they save you money? Maybe a little. If you dont game a lot then you could always either save two bios settings and reboot before gaming to turn the energy saving stuff off. If you game a ton then there is really no point leaving the energy saving on (again, my opinion)
There will always be lag with technology like this, even if it is parts of a second because it has to sense what it is doing to reduce or increase the speed and has to keep monitoring it and switching it (like you have been seeing) as use goes up and down.
DJ Tucker
Re: C1E and EIST?
Postby DJ Tucker » Fri Feb 13, 2015 11:10 am
well I have turnt it off as I didn't do much in the way of power saving as my pc is off most of the time anyway lol
Annihilator V3.0
Return to “Intel Processor Forum”
Who is online
