Outlook express error
ThomasSnow254
Legit Little One
Legit Little One
Postby ThomasSnow254 » Wed Oct 28, 2015 12:26 pm
Sometimes when I goto open an emali (any email new or old) I get the following errors
1) One or more parts of this message could not be displayed
then when I hit OK
2) There was an error opening this message.
There is not enough memory.
Nothing is added to the error logs
Why do I get this error??
I have 1gig of memory and from what task manager say I'm only using 1/2 of it.
How I fix it??
Short of rebooting??
Using Outlook Express 6
6.00.2900.2180 (xpsp_sp2_rtm.040803-2158)
KnightRid
Re: Outlook express error
Postby KnightRid » Thu Oct 29, 2015 5:45 am
Wow, 1gb of ram and outlook express 6? Are you still running XP?
Update outlook express to a newer version or update to windows live mail.
Empty deleted items folders in outlook express.
Get more memory.
Switch to another email program or get your email online through the web interface.
I am not sure if expanding your virtual memory settings would help or not but you could try that.
Just a few suggestions as you have such an old version of OE and a super low amount of memory.
RobertSHark2
Legit Little One
Legit Little One
Postby RobertSHark2 » Sun Nov 01, 2015 3:06 am
1. Register an important Outlook file. Go to Start > Run and type regsvr32 OLE32.DLL
Also, type regsvr32 inetcomm.dll
2. Check if DBX file is corrupt. Perform a repair with
Outlook Express Repair Toolbox
https://www.outlookexpressrepairtoolbox.com/
3. Create a new Outlook Express identity.
http://itknowledgeexchange.techtarget.c ... -dbx-file/
4. Repair or Reinstall Outlook Express.
https://social.technet.microsoft.com/Fo ... um=outlook
Return to “General Software Programs”
Who is online
