NZXT H440 :)
DJ Tucker
NZXT H440 :)
Postby DJ Tucker » Fri Mar 25, 2016 4:18 pm
so i'm getting the case above from my better half. In all of my previous cases I have had positive airflow from 40-70% more intake over exhaust. On this case I will be putting 3x 120mm aerocool shark fans on the front as intake and the same 3x fans on the top as exhaust. This will give me neutral airflow but I have a gpu taking some of the intake air and a rear vent that will be unused. would I not have negative airflow and if so what would that do to my temps? also how could I get positive airflow?
Annihilator
[b]Processor:
Intel Core i7 2600k @ 4.6Ghz (1.35v) LEPA Exllusion 240 Mod
Hard Drive: SanDisk X110 128Gb Sandisk X210 1Tb
Video Card: Inno3d GTX 1070 iChill Black 2100/9100
Monitor: Samsung C27F396FHU
Mobo: Asus Maximus IV Gene Z Gen 3
Case: Vector Custom VDM01 with Corsair HX1000i PSU
Peripherals: Corsair K70 Lux Corsair M65 Pro and Corsair Void Pro Wireless
sbohdan
Re: NZXT H440 :)
Postby sbohdan » Fri Mar 25, 2016 6:46 pm
You could probably install another 12cm fan on the bottom of the case to pull in air, where it is the coolest anyway. Just make sure you have a dustfilter there :)
Main rig: NZXT Phantom modded case with Danger Den WC, Gigabyte GA-P67-UD4-B3, 2500K@4.7Ghz,1.428V, 8GB GSkill Ripjaws 2133Mhz 10-12-12-31@1.6V, MSI GTX 1060 3GT OC, Asus 24" 1ms 144hz, 2xOCZ Vertex4 128GB RAID0, Samsung 2TB; PC P&C 750W, Win7 Ultimate 64
my complete GFX tuneup & cooling mod: viewtopic.php?t=3263&highlight=
KnightRid
Re: NZXT H440 :)
Postby KnightRid » Sat Mar 26, 2016 5:22 am
agree with sbohdan. Also you could lower the speed of the exhaust fans to allow more internal airflow as it wont escape as fast.
or..... http://midwesttowers.com/parts/fan-stacks/ - although your electric bill may go up slightly :supz:
DJ Tucker
Re: NZXT H440 :)
Postby DJ Tucker » Sat Mar 26, 2016 7:39 pm
think lowering the fan speed would be best solution as a fan on the bottom wouldn't be possible as it is encased to hide the psu.
Annihilator
[b]Processor:
Return to “Cases, Power Supplies, and Cooling”
Who is online
Users browsing this forum: No registered users and 7 guests
