New Q6600 Build
DJ Tucker
New Q6600 Build
Postby DJ Tucker » Fri Apr 08, 2016 9:38 am
I have just built my partner a new system.
Specs Below:
Processor: Intel C2Q Q6600 @ 3Ghz @ 1.3v With Zalman 9500 Cooler
Memory: 4Gb OCZ Nvidia SLi 667Mhz 4-4-4-12-2T
Hard Drive: 60Gb Kingston SSD OS/500Gb Samsung F1 HDD
Video Card: Zotac GTX 570 800Mhz/2000Mhz (Gelid Cooler)
Monitor: Viewsonic VA2216w
Operating System: Windows Vista Home 64 Bit
Motherboard: MSI P6N SLi V2
Case: Coolermaster HAF932 With Corsair GS800
This weird thing is, I have 3 of these cpu's pulled from old systems. The first 2 had the exact same vid of 1.325v had same idle (22c) and load (48c) temps and got same 3Ghz overclock (1.3v). However, the current Q6600 I have installed overclocks to the same 3Ghz @ 1.3v but idle temps are the same and load temps are very different. Idle (22c) Load (38c). That's the lowest temps I have even seen on a mid range air cooler. Are these temps a possible fault?
Annihilator
[b]Processor:
Intel Core i7 2600k @ 4.6Ghz (1.35v) LEPA Exllusion 240 Mod
Hard Drive: SanDisk X110 128Gb Sandisk X210 1Tb
Video Card: Inno3d GTX 1070 iChill Black 2100/9100
Monitor: Samsung C27F396FHU
Mobo: Asus Maximus IV Gene Z Gen 3
Case: Vector Custom VDM01 with Corsair HX1000i PSU
Peripherals: Corsair K70 Lux Corsair M65 Pro and Corsair Void Pro Wireless
KnightRid
Re: New Q6600 Build
Postby KnightRid » Sat Apr 09, 2016 3:52 am
q6600 brings back memories :)
I think it is possessed and you should hold a seance immediately :snakeman:
LOl seriously, I have seen multiple cpu's give multiple readings over the years but the 10c is a bit of a gap. I would not worry too much though. Anything under 55-60C would not worry me. If it consistently went over 60c then I would look at lowering the OC.
Run multiple temp programs on each and see if you still get the variance... http://openhardwaremonitor.org/ - there is one.
Could also be a sensor out of whack on the motherboard.
Still, I would not worry if it is under 60c.
DJ Tucker
Re: New Q6600 Build
Postby DJ Tucker » Sat Apr 09, 2016 7:24 am
i'm just worrying in case this is a little on the cool side. I mean its better than I have seen on water?
Annihilator
[b]Processor:
sbohdan
Re: New Q6600 Build
Postby sbohdan » Sat Apr 09, 2016 12:56 pm
The sensor is probably malfunctioning. That's all.
Main rig: NZXT Phantom modded case with Danger Den WC, Gigabyte GA-P67-UD4-B3, 2500K@4.7Ghz,1.428V, 8GB GSkill Ripjaws 2133Mhz 10-12-12-31@1.6V, MSI GTX 1060 3GT OC, Asus 24" 1ms 144hz, 2xOCZ Vertex4 128GB RAID0, Samsung 2TB; PC P&C 750W, Win7 Ultimate 64
my complete GFX tuneup & cooling mod: viewtopic.php?t=3263&highlight=
DJ Tucker
Re: New Q6600 Build
Postby DJ Tucker » Sat Apr 09, 2016 5:32 pm
if that's potentially the case then how would I know the real temps?
Annihilator
[b]Processor:
KnightRid
Re: New Q6600 Build
Postby KnightRid » Sun Apr 10, 2016 5:33 am
DJ Tucker wrote:if that's potentially the case then how would I know the real temps?
The motherboard has the monitors on it, not the case. Unless you have some crazy thing that has wires plugging into the Mb to monitor the temp and even then, the temps come from the MB.
Did you check BIOS temp compared to windows/case/anything else temps?
Another odd thing would be if you have too much/too little thermal paste between the cpu and heatsink on the other builds and you got this one perfect.
You would have to wait for Nate or another reviewer to check this out but I think there is a way to use an external heat sensor gun to check the temps. I am not positive on how they do it when they review but it may shed some light on another way to check.
If you have another build of the same thing still around, swap the cpu/heatsink and see what each gives in the others system.
Return to “Intel Processor Forum”
Who is online
