Problem with extracting files from ZIP archive.
ConorrMurphy
Legit Little One
Legit Little One
Postby ConorrMurphy » Tue Jun 14, 2016 11:36 am
Need help restoring backup files which were created by genie backup manager software.
I have lost some of the sequential files in the overall backup sequence.
The software vendor knowledge base claims that the almost 2-gig backup files are really
a zip file and should be able to unzip with any winzip type utility.
Problem and a question is: I get the zip files, unzip them and all files come out great but with
an extra extension. For example document.doc gets extracted as document.doc.genc file.
I rename the file to document.doc and even though the file size, creation date is fine the
file is unreadable. This applies to all files extracted this way. anyone had any experience with this?
Or what is a good zip un-corrupt utility out there?
KnightRid
Re: Problem with extracting files from ZIP archive.
Postby KnightRid » Tue Jun 14, 2016 1:39 pm
Swift Restore?
http://www.genie9.com/Support/Manuals/g ... estore.htm
The genc is because (from what I read) they do NOT use standard ZIP encryption just compression. You can extract the files but they are still encrypted.
I would email Genie (or call) and ask how to un-encrypt the files if the swift restore wont work.
MarcelBlazek
Legit Little One
Legit Little One
Postby MarcelBlazek » Wed Jun 22, 2016 10:05 am
Providing you have the professional version, and hopefully at least version 6.x. Open Genie Backup and go to Tools/Advanced Tools/Genie Eyes and decrypt all the backup files after unzipping them (by changing the main file extensions to .zip). This process will decrypt and make your files usable.
If that doesn't help, then the only option is to try to recover the files using ZIP Recovery Toolbox. I think that you will be able to save at least some files if not all.
Zip Recovery will not decrypt genie files as it is for fixing corrupt zip files which they are not...
focin albert
Legit Little One
Legit Little One
Postby focin albert » Fri Dec 02, 2016 12:06 am
I was facing same kind of issue but in my case it was due to improper configuration!
Who is online
Users browsing this forum: No registered users and 9 guests
