SSD space disappearing?
KnightRid
Re: SSD space disappearing?
Postby KnightRid » Sun Jun 11, 2017 1:36 pm
Also run windirstat as admin and see if it changes what is showing as the culprit.
Sent from my SM-G950U using Tapatalk
camaroguy1998
Postby camaroguy1998 » Sun Jun 11, 2017 1:48 pm
KnightRid wrote:Chkdsk /r if you have not tried that. Make sure to do it from elevated cmd.
I ran chkdsk, as Admin, it showed no errors.
Windirstat as Admin, No Change. C= 43GB, Windows = 29.9GB
Windows/Explorer= 445MB free of 223.5GB
Whatever file it is, seems to be expanding and contracting!
ASUS BW-12B1ST BD Burners(X2)
EVGA 560ti SC
ASUS 27" LED LCD monitor
Corsair 600T case
KnightRid
Postby KnightRid » Sun Jun 11, 2017 7:12 pm
system restore points. maybe it is no erasing them...yea i am pulling at straws right now and I already took all my pills (gabapenin hydrocodone and ambien so I am a bit off kilter too) Oh and Four Rses bourbon cause it helps the medicine og down :)
camaroguy1998
Postby camaroguy1998 » Sun Jun 11, 2017 10:19 pm
KnightRid wrote:system restore points. maybe it is no erasing them...yea i am pulling at straws right now and I already took all my pills (gabapenin hydrocodone and ambien so I am a bit off kilter too) Oh and Four Rses bourbon cause it helps the medicine og down :)
Ok, you can quit pulling at the straws!
I used your instructions on determining where the Temp file is. It showed me a temp file under my user name. So, I made an A$$ out of U and Me by assuming it was the temp file I needed! Wrong!
As I was Grasping at straws, ](*,) I opened the Windows folder and there's the windows Temp folder. I right clicked it and damn if it didn't say it was 181GB. #-o 8-[
So I deleted 75% of what was in it! I left it in the Recycle Bin(rather be safe than sorry) and it opened my C drive to 163GB free of 223GB!
So far its running fine and I don't get any Free Space Warnings!
Thank You KnightRid for racking your brain and pulling at straws! =D>
:drinkers:
EVGA 560ti SC
Corsair 600T case
KnightRid
Postby KnightRid » Mon Jun 12, 2017 4:15 am
LOL - I never even thought about another temp directory either. I just figured it was the user one too!!
Glad you got it man.
I would delete everything out of there as it is not needed. Windows is just too dumb of an OS to erase the temp folder after installing programs and updates.
Return to “Storage”
Who is online
