How to increase MacBook speed?
Operating Systems
If its an OS, its here.
Dooles
Legit User
Legit User
Postby Dooles » Mon Oct 23, 2017 8:18 am
Guys, sometimes my MacBook Pro is running so slow (early 2015, sierra).
What can be the reason? And how can I fix it? ](*,) ](*,) ](*,)
KnightRid
Re: How to increase MacBook speed?
Postby KnightRid » Tue Oct 24, 2017 4:20 am
https://macpaw.com/how-to/fix-mac-running-slow
I don't have a Mac but hopefully that can help.
If it is slow on the internet, it is your internet provider that is the problem. Either you have slow speeds through them or are not getting the speed you should. If the computer is slow outside of the internet then the above link might help.
Does yours have a SSD? if not, that would help.
Rilan
Legit User
Legit User
Postby Rilan » Tue Oct 31, 2017 3:47 pm
Dooles wrote:Guys, sometimes my MacBook Pro is running so slow (early 2015, sierra).
I have few Mac speed up tips. First of all, it's important to delete old apps or useless files. By the way, there are plenty of hidden files that can make your Mac slow. Also, you can use cleaning utilities.
Return to “Operating Systems”
Who is online
