mATX curiosity
- stopthekilling77
mATX curiosity
okay so Ken piqued my interest when he mentioned a cheap mATX board with integrated GFX as a solution for a cheap PC over here: http://forums.legitreviews.com/viewtopic.php?t=10059
got me wondering about these boards, as i'm looking to build a new family computer here in a few weeks.
seeing that post got me thinking and now i'm searching wikipedia and newegg to research them.
thoughts: i'm guessing that due to it's smaller form factor, it is less bound to produce a lot of heat? another guess is that i'd be limited by how many PCI slots there could be, right? would it fit in a regular old run of the mill PC case? any advantages or disadvantages to these guys?
feel free to voice any and all opinions here!
Cyberpower generic case
B450M PRO-VDH MAX
Ryzen 5 3600 w/PBO/OC
CM Hyper 212 EVO push/pull
Samsung 970 EVO Plus 500GB
6GB Seagate HDD
EVGA 650BQ 650W PSU
MS LXM-00001 keyboard
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
All my stuff is mATX, went that way for the fact that I'm tight on room. The draw back to the mATX shows its head when you go to add stuff to them. Your not going to get an 88XX card in a mATX case, a 79XX card is snug in my case. I'll snap you a pic of my setup tonight to show how snug a mATX case can get.
But if its going to be the community whipping post for the family to do email and such then your most likely not going to go all to high end.
-Thomas Jefferson
-Thomas Jefferson
- stopthekilling77
sounds good, i'm gonna familiarize myself with the layout, and consider it for the family. i'll post what i have right now in the current family pc, and i'm lookin forward to those pics, they'll help me visualize what i'll be able to shove in the new onebubba wrote:All my stuff is mATX, went that way for the fact that I'm tight on room. The draw back to the mATX shows its head when you go to add stuff to them. Your not going to get an 88XX card in a mATX case, a 79XX card is snug in my case. I'll snap you a pic of my setup tonight to show how snug a mATX case can get.
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
Here ya go, the case is a Centurion 541 mATX case, the cooler is a Zalman 9700 LED (I know I need an 120 intake and exhaust fan, its on the to-do list)
The case comes with a lower drive cage for the hard drives, I didn't use it due to the fact it's to close to the ram for my liking. I just put the drive up in the 3.5 bay.
-Thomas Jefferson
-Thomas Jefferson
- stopthekilling77
coolness! thanks Bubba! interesting how they'd put the harddrives down at the bottom of the case... anyhow i pitched the idea to my dad, and he's pumped at the notion of saving some money AND getting a new pc who wouldnt be?
i'm going to do some snooping on newegg and see if i can't throw together an inexpensive replacement to the one running now.
btw i like how the size of the case/board makes the HSF look HUGE lol
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
- HONkUS
I put in mATX board for all my computers at work, their all Biostar T-Force board they are Socket 939, use Nforce 4 410 chipsets with Geforce 6100 IGPs. Haven't had a single problem with them. I put newer mATX AM2 boards in my dad and step dad's computers and they have both worked flawlessly as well.
- stopthekilling77
possible to install 120mm fans on the Centurion 541?
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
- stopthekilling77
hmmmm my brothers pushing for enough room to pack in a good video card, i'm wondering if i couldnt just put the mATX mobo that i chose: ASUS P5L-VM 1394 LGA 775 Intel 945G Micro ATX Intel Motherboard into a COOLER MASTER Centurion RC-534-KKR5 Black Aluminum & Mesh bezel, SECC chassis ATX Mid Tower
mATX mobo in an ATX case to make room for an 8800 or 8600? can i do it?
and one more thing, one review stated:
i'm planning on getting the E6420, what could i expect to OC to with that limited FSB?Cons: LAN shuts down around 320fsb which severely limits OC'ing. WinXP Standby/Hibernation were intermittently inhibited due to using PCI video since BIOS does not completely disable onboard video.
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
yeah most, if not all mATX are not meant to be overclocked, here is the review of the board I have and how far they were able to push it.
http://www.legitreviews.com/article/419/10/
everything should fit in that case, the thing that will cause issue with the 88xx card in the case is the clearance to the drive bays, you may have to loose the middle section to allow the length of the card like http://forums.legitreviews.com/viewtopic.php?t=7942
-Thomas Jefferson
-Thomas Jefferson
- DaIceMan
my mini boards LAN flakes out when you start to overclock as well. Simple solution... I added a PCI gigabit NIC card for $20.
I have mine in a "plain" ATX case, with an E6400 and a Thermaltake Big Typhoon cooler. I can't really get the side panel on with it there (limited air flow) but one of these days I'll cut a breather hole in the side.
