I am having some problems with my xbox 360 and a AV to VGA adapter that plugs into a spare montior I have.
I know the Xbox 360 video cable is working fine(tested it on a normal TV: both HD and TV).
The montior is working fine with VGA tested it with a computer.
The adapter is works fine with 24" Acer Monitor(friend of mine), but when trying to use it on my LG it does not display a picture at all.
I messed around with the video settings on the 360. Nothing seems to work am I going to have to bite the bullet on an actually Xbox 360 VGA cable?
I have searched the internet for forums on this issue, nothing has my exact issue anywhere (I have searched). Thought I should visit Legitreviews for some help.
Montior Spec.:
http://www.lcdnfo.com/html/LG_Flatron_L ... nitor.html
Xbox 360 + VGA Adapter = Fail?
- InspectahACE
Re: Xbox 360 + VGA Adapter = Fail?
well..with that monitor id say the xbox vga cable might be the only way...judging from an outsiders point anyway(i dont have an xbox)..only other thing i can think of is using the component cables to the video card with the s-video adapter(assuming you have one that came with the card)..you would probably need a program to utilize that s-video/component cable too(like a media center type thing such as ATI's Catalyst Media Center or somethin else)..that worked for me when i hooked up my N64 to my monitor..
