What is the best brand for an AVR?
- Legit Enthusiast
i currently looking for an avr with a good performance that will suit my pc's needs.
Intel Core i5 750
Gigabyte P55 UD3P
2x2GB G.Skill Ripjaws
HIS IceQ 4+ turbo HD 4870 1GB
WD 500GB
OCZ 600W psu
Thermaltake V3 Black edition (installed 5 Akasa blue led light fan + 1 blue led stock fan) with sunbeam uv light
LG W2043T
Altec Lansing V2621
Gigabyte P55 UD3P
WD 500GB
OCZ 600W psu
LG W2043T
Altec Lansing V2621
- Sporg
Re: What is the best brand for an AVR?
Automatic Voltage Regulator? Which is built into most of the good UPS setups?
What are your needs?
~Bertrand Russell
~Bertrand Russell
- Legit Enthusiast
yes automatic voltage regulator. just for my pc and printer.
Intel Core i5 750
Gigabyte P55 UD3P
WD 500GB
OCZ 600W psu
LG W2043T
Altec Lansing V2621
Gigabyte P55 UD3P
WD 500GB
OCZ 600W psu
LG W2043T
Altec Lansing V2621
does your utility provide a very unstable supply of power the you need to have it regulated? you would save yourself some money by just buying a UPS to prevent surges or powerloss.
- Sporg
Personally I always go with a UPS that has AVR - helps keep that power nice and clean.
~Bertrand Russell
~Bertrand Russell
i dont even use a UPS.. though i prob should
Same here...knock on wood...even though I have not had a single issue in over 15 years!smack323 wrote:i dont even use a UPS.. though i prob should
- Skippman
I use a lot of Tripp Lite products. I also have two UPS's by APC that work great as well.
- Legit Enthusiast
well then, I will look more on UPS with AVR I think.. Personally, its worth having an avr especially when your area/region has an unstable power distribution. instead of 220-240 it might spike to 250 or more. that would be good for my pc. What is the benefit of having an UPS anyway?
Intel Core i5 750
Gigabyte P55 UD3P
WD 500GB
OCZ 600W psu
LG W2043T
Altec Lansing V2621
Gigabyte P55 UD3P
WD 500GB
OCZ 600W psu
LG W2043T
Altec Lansing V2621
Smooth/regulate the voltage that it discharges. Most people use them for power failures. If you are working on your PC and the power goes out a UPS gives you time to save your data and properly shut down the computer.
- Legit Enthusiast
okay thanks. yeah I work a lot in my computer. maybe I need it.
Intel Core i5 750
Gigabyte P55 UD3P
WD 500GB
OCZ 600W psu
LG W2043T
Altec Lansing V2621
Gigabyte P55 UD3P
WD 500GB
OCZ 600W psu
LG W2043T
Altec Lansing V2621
