Can anyone tell me if the Corsair Hydro H100 water cooling kit will cool both the cpu and the video from the one pump.
My Apogee pump did this OK until after 8 years of faithful service it gave up the ghost.
Thanks a lot, Bob
Water Coolers
Re: Water Coolers
It can't. The H100 is a sealed loop system, only cools the CPU.
From the sound of it you have the Apogee Drive (pump/water block combo). Just get a couple feet of new hose, a pump, and an updated water block and refill you current loop.
Pump: MCP355 http://www.swiftech.com/mcp35512vdcpump.aspx
Block: Apogee XTL http://www.swiftech.com/apogeextl.aspx
Upside to the system you have, when it dies you can replace parts. With the H100 you cant, toss the whole unit.
-Thomas Jefferson
-Thomas Jefferson
