PSU Idea
- DJ Tucker
PSU Idea
I know I have been posting a lot of questions as of late but this is my final one for a while as I will be away. anyway as you all know I have a coolermaster haf 932 advanced and my psu is mounted at the bottom with the fan inside the case taking cool air from my 4x 120mm fans (65cfm each). however I don't plan on getting a water cooler just yet if at all and was thinking to utilise the huge amount of space at the top of the case, could I put my psu at the top mount with the fan facing the top vent so it has it's own airflow with a 120mm fan next to it as intake? this is to help take the stress off my 2 gtx 580s as the bottom 580 is close to the psu
MSI Z590 Gaming Edge Wifi
Corsair XR5 240mm x2 & 360mm
Corsair HX1000i
Lian Li O11D
Corsair HX1000i
Lian Li O11D
Re: PSU Idea
Not sure what would cause stress on the card, unless you think there is not enough space between the card and the PSU for good air flow.
I would have the fan side of the PSU pointed down. Thats what the vent in the bottom of the case under the PSU is for.
Putting the PSU up in the top wont hurt anything, just make it a little more top heavy.
-Thomas Jefferson
-Thomas Jefferson
Re: PSU Idea
That.bubba wrote:I would have the fan side of the PSU pointed down. Thats what the vent in the bottom of the case under the PSU is for.
If the PSU is getting that hot where the fan is not cooling it well enough, you may want to look for a new PSU because the heat will end up killing it anyway. I have the haf932 myself but have a Thermaltake Water 2.0 radiator/fans attached to the top panel instead of the stock fan. I only have the one gtx660 video card with an Antec 850w psu, core i7-3770k, 32gb ram, 6 hard drives and a bluray writer and my psu is warm but never hot even during gaming sessions.
I would be real concerned if the PSU is getting that hot!!!
- DJ Tucker
Re: PSU Idea
my psu isn't getting hot just the gpu that is 3cm above it. the fan on the psu is much better at sucking in the cool air from my 4 120mm side fans than my gpu. it meant my poor gpu was being starved or air. so to hopefully stop this I decided to go ahead and have a crack at putting my psu at the top with the fan facing the top vent.
my 2 gtx 580s have dropped in temp quite a bit. top card dropped by 5c load and bottom card 12c load. from that my cpu dropped 4c load and my psu with a thermal adhesive strip attached to the bottom is 2c warmer at full system load. so it seems that this has become a much better choice. also cable management from the top mounting bay was easier.
Corsair HX1000i
Lian Li O11D
Corsair HX1000i
Lian Li O11D
