Make your own Windows
If you're like me, then you probably hate all the crap that Windows decides you need to achieve the best performance on your computer. I'm talking about all those programs that get instaleld with a fresh copy of Windows and just hog your disc space and resources. Well, my friend showed me this neat site that allows you to decide what you want to include in your Windows, and then lets you install just that. Check it out, it's a pretty sweet tool: http://nliteos.com/nlite.html
- Dragon_Cooler
OMG thats awsome!
Thank you very much.
- Corsair 800D | Corsair HX850W | LG 20X DVD+/-RW | TRUE 120 | Intel I7 920 D0 @ 4.2GHz (200X21, 1.275v) | Intel X25-M G2 120GB | 2 - WD Green 2TB | 6GB OCZ Platinum PC3 12800 | EVGA X58 SLI | X-Fi Platinum | EVGA GTX 480 (780/1970)
- Dell U2311H 23in (IPS) | Saitek Eclipse II | Razer Boomslang 2007 CE | Razer Exactmat
- Legit User
Hey thats cool tool ! looks good. I may give it a try next time I reformat. But I have been using a program call xp aintispy to disable all the error reports and mesenger. I have to reinstall all the windows patches and reactivate windows and then I install xp aintispy and it runs in the background. Big hasil though! Need to Get a new copy for sure! this may be the ticket!!!
