My Setup
SlipSand
Legit Fanatic
Legit Fanatic
My Setup
Post by SlipSand »
OK I know it's been a while for me but I havent update you all here.
I currently Have:
DFI NF4 Ultra-D
1GB Mushkin BH5 @ DDR500 2-2-2-11 3.6V
AMD 64 3200+ @ 2.5ghz
BFG 7800GT OC
OCZ Powerstream 600W
120GB Caviar
X-Fi Xtreme music
All on Air. Will get picys.
Any I deas on how to OC more. I have Tmods up on the BIOS but idk how to make it faster. I know that sounds noobish but I've had to reinstall windows 5x because of Bad OC's so far.
werty316
Post by werty316 »
Tryin increasing the CPU and chipset voltages and use a lower memory divider.
SlipSand
Legit Fanatic
Legit Fanatic
Post by SlipSand »
Yeah the CPU volt is at 1.55
And I like the DDR 500 but I'll try some of your advice this Sun at my friends LAN. :)
kenc51
Post by kenc51 »
Yeah I'd also say lowering the rams speed......it's already near it max if you need 3.6v. You should be able to get some more MHz from that CPU!
werty316
Post by werty316 »
Not having a 1:1 like AXP days doens't hurt an A64 as long as you keep it above 200MHz so use a memory divider so you can increase the CPU speed.
topsub
Legit Aficionado
Legit Aficionado
Post by topsub »
not bad...
Skippman
Post by Skippman »
Not a bad little rig you have there.
