Overhaulling the rig (Read S.T.A.L.K.E.R. is killing my PC!)
- Skippman
Ok, so it's that time again. Time to evolve the PC into the next level. Here is what I'm currently running.
abit A8-32X
AMD Athlon 64 3700+ 939
2G DDR400 Corsair XMS RAM
HIS X1900XT Radeon 512M (Non Crossfire controller)
OCz 600W PSU
80G 10,000RPM Raptor SATA Drive
That's the mission critical components.
I HAD planned on just upgrading to a X2 or FX processor but those are apparently impossible to find. And with more and more games requiring dual core I need to make the change now, or find myself on the bottom end of the curve.
I'm also looking to get another X1900 to do Crossfire with.
So, I need to move to the next level and need recommendations. I plan on doing no overclocking. I prefer to passivly cool my rig if possible. I prefer AMD processors but wonder about the life of the AM2 socket.
Advice?
abit A8-32X
OCz 600W PSU
Advice?
How much money do you have to throw into this? That really dictates (ultimately) what people buy...
Play
Work
Work
Well, in a matter of speaking, yes. I'd suggest going Intel unless you're going to die without an AMD CPU. Intel is really cleaning up right now. A nice E6300 or E6600 paired with a CrossFire mobo will do you good, as will 2GB of quality non-overclocking DDR2-800. Keep your videocard and everything else, actually. You'd be replacing the CPU, memory and motherboard. That's it, thankfully you have a PCI-Express videocard.
Play
Work
Work
- Skippman
Ok, so I'm going to make the leap. I need advice as I've not dealt with Intel gear in years.
Aside from the DFI Lanparty motherboard, is there another Intel board that supports Crossfire? I know this is probably a pipedream since AMD now owns ATI but I do not like nVidia nor do I have intentions to sell my X1900XT.
I've been told by various associates that some versions of the Core2Duo can be overclocked to twice thier rated performance. Is this true?
I am running stalker fine on my fx-60 and 2gigs of ram and x800xt. you just trying to run it completly full? cuz I have it on 1680x1050 and medium to high settings. s939 dual cores 3800+ (2.0) can be found for 99 after rebate on tiger direct oem and get a good cooler on them and you can have them running 2.4-2.6ghz.
- Skippman
I'm running at Medium detail at 1920x1200, my monitors native resolution.
I'm thinking of taking the plunge to Intel. How does the followin system stack up?
ASUS P5B Deluxe Motherboard (Says it's Crossfire capable)
Intel E6600 Conroe Proc
Corsair XMS2 Dominator 2GB (2x1GB) DDR2 TWIN2X2048-6400C4D RAM
Think that should do it? That's right at about $800. I've read the E6600 is extremely overclockable due to its low voltage.
- Skippman
Ok, further refining my shopping list and needing information still. I appreciate all the input I've recieved so far on my numerous questions. When dropping $1K I like to be happy with my purchase.
Here's what I'm starting with:
abit A8-32X
OCz 600W PSU
200G 7,200 WD storage drive (for ISO's)
Here's what I'll be going to:
Asus P5W DH Delux
Intel Core 2 Duo E6600 Conroe
HIS X1900XT Radeon 512M x2 Crossfired
OCz 600W PSU
200G 7,200 WD Storage Drive
My questions are now down to RAM. While I'd love to buy, and have no problem paying for, Corair Dominator RAM I wonder if I'll actually see an improvment over more "economical" priced Corsair or OCz products given that I'll be OC'ing the processor. I know next to nothing about new generation OC'ing. When I was doing it all you had to do was change the clock multiplier. Someone told me you have to downclock the FSB to increase the speeds. If that's the case will buying "faster" RAM be worth it?
Also, until this point I've been using a Thermaltake passive heat pipe based cooler, and it's worked great for my system up until this point (even on my 64 3700+). I'm assuming I'll need to replace this even though I have an adapter for Intel boards?
abit A8-32X
OCz 600W PSU
Asus P5W DH Delux
OCz 600W PSU
How much are you planning on overclocking the E6600? It might be OK if you're not going to push it too far. Without knowing what it is, it might actually be worse than the stock Intel cooler you get with the E6600. Though I would recommend a newer (read active) cooler for any serious OC'ing.
Again with RAM choices it depends on how much you plan on overclocking and how much you want to push your RAM.
Intel overclocking generally works like this:
CPU Speed = FSB speed * CPU Multiplier
e.g. 2403Mhz = 267 * 9
Memory Speed = FSB speed * Divider
e.g. 400Mhz = 267 * 2:3
(The divider is FSB:RAM ratio, take your FSB speed, divide it by the first number and times it by the second, e.g. 267/2 = 133, 133 * 3 = 400)
So to get a successful (stable) CPU overclock you will have to change the memory dividers (there are usually 1:1, 2:3, 5:3 etc options) and reaching the CPU's maximum usually either means you have to overclock or underclock the memory. Choosing a fast speed memory will usually give you the option for better play at overclocking it or allow you to underclock it and still have it running pretty fast.
Hope that helped you in figuring out the overclocking game and deciding if expensive RAM is worth it.
Dan
Dan
Ok, well if your board has unlocked lower CPU multi's (most good boards do lately with the latest BIOS) there will be several ways to play it, if you want to, just have a mess around with them but the best option would be this:
CPU Speed = FSB Speed * CPU Multi
3200MHz = 400 * 8
Mem Speed = FSB Speed * Divider
400 = 400 * 1
This will allow you to run your RAM at its rated 400MHz with a 1:1 divider (and 1:1 is supposed to give the best performance or something).
As with any overclocking, take it up from stock a few MHz at a time and burn it in some at that speed. You may have to increase the Vcore of the CPU if it starts to become unstable as you are cranking it up, increase it by +0.05v at a time and check if it made it stable (shouldn't have though you'd need more than 1.4v max for that speed).
For cool/quiet cooling get one like these: Scythe Ninja, Tuniq Tower, Thermaltake Big Typhoon.
Dan
3200MHz = 400 * 8
400 = 400 * 1
Dan
- Skippman
Dan,
Thanks for your input. I appreciate hearing from someone who has the same processor as I do. So I should go ahead and get the Corsair Dominator RAM as I'll be able to fully clock it, as opposed to a lower cost 667 module?
The Dominator modules have the following variables:
Memory Speed: 800MHz PC2 6400. Memory CAS Latency: 4-4-4-12.
So, in theory according to your above information I can clock that RAM at half the FSB speed and get 400mhz 2-2-2-6?
No.
The 400Mhz I quoted is what the system sees the RAM speed at, as its DDR(2) it will access it twice every MHz. So its still 800MHz RAM. The timings are independent to the speed, so will remain at 4-4-4-12 unless you change them (probably best you leave that till youve read up a lot more).
So you will still need 800MHz RAM. But its up to you if you want to get the dominators (which will be cooler, and overclock better if you ever decide to push your RAM over 800) or some other 800MHz 4-4-4-12 RAM.
Dan
Dan
- Skippman
Asus P5W DH Delux
And as we discussed in this post:
http://forums.legitreviews.com/viewtopic.php?t=9145
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
Timing 4-4-3-5
Cas Latency 4
Voltage 2.0V - 2.1V
Total project cost, $691 shipped. A full $100 under budget.
Timing 4-4-3-5
Cas Latency 4
Voltage 2.0V - 2.1V
Intel?!? Save your money... your eyes can't tell the diference between these "low"!!! end CPU C2D 6300/400 and AMD X2 4200+ and higher
Here is my tip
AMD X2 4200+ (ADO4200IAA5CU) if no OC in mind then chose the 4800+ or the 5000+
2x 1024Mb DDR2 GSkill PC2-6400 (800) CL5 NQ or PK
for ATI Crossfire...
ASUS M2R32-MVP DELUXE or Foxconn C51XEM2AA-8EKRS2H (for OC)
for Nvidia SLI
Gigabyte GA-M59SLI-S5 nforce 590 SLI(3)
You already have ATI so keep with it.. or wait a while and see the Nvidia 8600 DX10 rig that it's poping out any day soon
Here is my tip
for Nvidia SLI
- stopthekilling77
congrats man, i always get a tinge of jealousy when other people get to order their parts! my wish list has been sitting on newegg for months and months now just waiting for me to press the "buy now" button!
sounds like you'll be having some fun soon!
Cyberpower generic case
B450M PRO-VDH MAX
Ryzen 5 3600 w/PBO/OC
CM Hyper 212 EVO push/pull
Samsung 970 EVO Plus 500GB
6GB Seagate HDD
EVGA 650BQ 650W PSU
MS LXM-00001 keyboard
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
