Installing Windows Vista with a USB Flash drive was a tricky endeavor, but that all changes with the upcoming launch of Windows 7. Read on if you want to find out how you can install Microsoft's upcoming operating system from a USB key with our step-by-step directions from either Windows XP or Windows Vista!
Now we need to make the NFTS partition we just made active. This is where MBRWiz comes in. If you haven’t downloaded it, get it now and for simplicity, save it to your desktop. Click Start then Run. In the Run window type CMD and click ok. You should now be looking at the COMMAND window. Now we need to change directories so we can see the Desktop that is done by typing CD DESKTOP and hitting enter. Now we need to see what number Windows has assigned the thumb drive; to do this type MBRWIZ /LIST and hit enter. Mine is number 5.
Wow that's a lot of steps. Even with Vista all I did was copy the contents of the DVD to my thumb drive. Reboot, enter the BIOS, select to boot from the flash drive and it was off. I even did it this way with a beta copy of Windows 7.
Major_A wrote:Wow that's a lot of steps. Even with Vista all I did was copy the contents of the DVD to my thumb drive. Reboot, enter the BIOS, select to boot from the flash drive and it was off. I even did it this way with a beta copy of Windows 7.
I tried to do it that way and my netbook wouldn't boot to it. Thus my search began to find a way to do it. I found several, some worked for PC not for my netbook, some wanted special software that had to be bought, some went as far as virtual drives and mounting the ISO. This is what I found to work no matter what, on any system, and didn't cost anything.
-Thomas Jefferson
I'm trying to make the x64 version of Windows 7 bootable on USB, but the message I get says
This version of G:\BOOT\BOOTSECT.exe is not compatible with the version of Windows you're running. CHeck your computer's system information to see whether you need a x86 (32-bit) or x64 (64-bit) version of the program and then contact the software publisher.
Any ideas for making it bootable in vista 32-bit?
Intel Core 2 Duo E6600 @ 3.0GHz
Gigabyte GA-P35-DS3R
2x1gb G.Skill DDR2-800 4-4-3-5
eVGA 8800GT SC with Akimbo cooling Kit
WinXP Pro
Dell 2405fpw @1920x1200
Sounds like you are trying to install the x64 version inside of a x86 OS. This guide is to install the operating system the same way you would with the original DVD.
This is true, to get a 64bit USB key from a 32bit OS like XP because the 64bit BOOTSECT.EXE will not run in a 32bit OS. you need both 32bit and 64bit Windows 7 disk ISO's.
First set up the drive as per my article with the 32bit files, then after running the BOOTSECT.EXE delete the files from the drive (do not format) and copy over all the 64bit files and you should be good to go.
-Thomas Jefferson
I actually just got a version of bootsect that is x32 and spent a little time thinking about what the guide is actually doing and figured out I really just need to run the x32 version of bootsect.exe and it doesn't have to be the one from the USB drive.
G:\BOOT\BOOTSECT.exe /nt60 G: can be turned into.....
C:\Temp\boot\bootsect.exe /nt60 G:
C:\Temp\boot\ is where I downloaded the 32 bit bootsect and G: is the letter assigment of my USB drive.
WOrks like a charm. Also, the article has a typo in the command above. Right now it reads....
X:\BOOTBOOTSECT.EXE /NT60 X:
Needs to read.....
X:\BOOT\BOOTSECT.EXE /NT60 X:
Edit: Re-reading my post sort of sounds like I'm being condescending. This is a great guide and I changed my wording a bit.
Thanks again LR!
WinXP Pro
