spyware
spyware
I know how much you guys love getting stuff like Bargain Buddy and 180Search getting installed on your computer for no good reason and the thrill of hunting them down with Ad-Aware and Spybot S&D later on after your computer becomes slower than 166MHz Pentium that you left in the attic a few years back. That's why I decided to share this blog I found with you about top 5 worst sites to download from: http://blog.siteadvisor.com/2006/01/the ... rs_in.html
good call man! Add another: http://www.themexp.org, used to be good but now installs crapware. If I have to install stuff from questionable sites, I activate Ad-Watch and the Spybot background agent...they work.
Play
Work
Work
since I use kaspersky antivirus, I'm spyware and virus free (I check once a week with the following spyware killers: ad-aware, spybot S&D, noadware, spysubtract, xoftspy and they find nothing )
Main rig: NZXT Phantom modded case with Danger Den WC, Gigabyte B550 Aorus Elite, Ryzen 5800X @ stock, 32GB Patriot Viper DDR4 3200Mhz 16-18-18-36-1T, AMD RX 5700XT + AlphaCool WC, ACER Nitro XV2 27", SP 1TB nvme PCiE GEN3, Samsung 2TB; Cooler Master MW Gold 650W, Win10 Pro 64
