File name: CoD4MW-1.5-PatchSetup.exeDESCRIPTION:
This is the release of the v1.5 Call of Duty 4: Modern Warfare patch by Infinity Ward.
CHANGES:
Fixed server browser not showing all of the servers
The "hold [ ] to steady" sniper scope hint will only appear if you can use it
Fixed game not recognizing IWDs existing if they are all in fs_basepath and none are in the main/ folder
Made mod scripts able to change stats
Allow developer_script for mulitiplayer modding
Fixed map rotation errors with usermaps
Fix for reloading several times after connecting to a modded server
Fixed minimap not showing up in the menu for usermaps
Fixed an issue with Http redirect downloads.
Mod tools will now work with other languages
NOTE: patch 1.5 is not compatible with 1.4. You will not be able to find 1.4 servers if you update.
NOTE: Please ensure you have previously downloaded 1.4 patch before downloading 1.5 as you will need the 'Winter Crash' map from 1.4.
File size: 10.65 MB
MIRRORS:
Gamespot
WorthPlaying
GamersHell
