DaIceMan udpate...
- DaIceMan
DaIceMan udpate...
update 1, core system (aka PACE palit, AMD, Corsair, ECS); I'm an idiot, and the system still isn't built. Went to build it last week, realized my power supply I planned to use was a 20 pin, not 24 as the ECS motherboard requires. no one local carries the 20 to 24 pin adapter, so I ordered the new power supply (OCZ stealthXstream 500) and set aside time this morning to "get er done". I didn't. Got everything out, realized the cooler I planned to use (tuniq tower 120) didn't have a bracket for the AM2, only for K8, which doesn't work. Gonna try to borrow a cooler from a buddy tomorrow, and if it works, the system will be up and running tomorrow night before I sleep. if not, I'll order a new one tomorrow that will be here on Wednesday.
next, server issues. Got the motherboard back from RMA. ASUS turnaround time was pretty quick, so I had the system up and going. Ran into COUNTLESS lost hours of Folding due to (mainly) AVG crash issues. For good measure, i reinstalled windows today, and switched to Avast! thanks to the recommendation of many of you here at LR. Got the 2 GPUs rocking again, and everything so far ( an hour or so) seems to be stable.
Current productivity:
gamer, 5814ppd
wife's, 5078ppd
srvr1, 5409ppd
srvr2, 5409ppd
daily, 4898ppd
total current productivity, 26608ppd. It's usually sitting around 26.5-27k ppd, so hopefully with the server crashes sorted, I can start to reap some of those points I've been losing every day and start adding a little more to the daily output. Certainly once I get the PACE up and running, I should be adding another 5k or so a day bringing my addition to Team 38296 to around 32,000 ppd.
gamer, 5814ppd
wife's, 5078ppd
srvr1, 5409ppd
srvr2, 5409ppd
daily, 4898ppd
- martini161
- Mr Awesome
Re: DaIceMan udpate...
if it helps i found the core system to be worth aruond 7-10k ppd depending on how you get it set up ive got a vm for folding set up, ive got the .torrent file ready and im seeding let me know if you want it
What's this folding file you're talking bout? Is it the one where you made your own VMware which is made solely for folding? If it is, it won't work on my E7200 right since it doesn't support VT?martini161 wrote:if it helps i found the core system to be worth aruond 7-10k ppd depending on how you get it set up ive got a vm for folding set up, ive got the .torrent file ready and im seeding let me know if you want it
@DaIce. So you're going from like 20k a day to 27k a day? Those are some really nice setups that you got there. Glad to hear that your server rig is fixed.
Gigabyte Z77X-UD5H F14 BIOS
ASUS GTX 460 768MB @ 800/1950
Corsair AX750
Crucial M4 128GB
Western Digital Black 1TB
Cooler Master Hyper 212+ EVO
BenQ E2420HD
I AM CANADIAN!
Corsair AX750
Crucial M4 128GB
BenQ E2420HD
I AM CANADIAN!
- DaIceMan
yeah, meant to say that. GPU will get me 5k or so. Gonna look into SMP for both the quads when time allows to try and pull another 4-5k ppd. Gotta do something to keep wickedld9 from catching me before I have a chance to chase down DS.
Glad you got it sorted!
Oh, you can run, just not fast enough...
- DaIceMan
you done any overclocking on the 9600GT yet? I just got mine Folding and was curious where you were if so. If not, I'll post up my overclock numbers in a couple days when I've had time to tweak on it a while.martini161 wrote:if it helps i found the core system to be worth aruond 7-10k ppd depending on how you get it set up ive got a vm for folding set up, ive got the .torrent file ready and im seeding let me know if you want it
- martini161
- Mr Awesome
i did have it overclocked pretty high on the shaders, something lik 1800-1900 but then when the new WU came out that were EUE'ing like crazy i just brought it to stock and left it there.
- DaIceMan
what are you seeing for ppd on the GPU?
- martini161
- Mr Awesome
fahmon gives me like 4-5k depending on the unit
- DaIceMan
hmmm, guess my card isn't being pushed hard enough then. I'm only getting 3100ppd on a P5506.
- DaIceMan
Seems to be speedstepping when the screen saver kicks in. Are you experiencing that at all martini?DaIceMan wrote:hmmm, guess my card isn't being pushed hard enough then. I'm only getting 3100ppd on a P5506.
- martini161
- Mr Awesome
not that ive noticed.DaIceMan wrote:Seems to be speedstepping when the screen saver kicks in. Are you experiencing that at all martini?DaIceMan wrote:hmmm, guess my card isn't being pushed hard enough then. I'm only getting 3100ppd on a P5506.
