We have a new GPU core (core 15) going into an open beta test for NVIDIA clients. This core requires a new client (see below) as well as the latest drivers (197.45). This core is the first run of the GPU3 technology, derived from the OpenMM project at Stanford (http://simtk.org/home/openmm). You can find more information in our GPU3 FAQ (see url below).
While this release is for NVIDIA only to start, we are actively pushing ATI support (with the help of AMD/ATI), although we have no ETA at the moment. However, please do not use this client with an ATI GPU at the moment.
This is the first open beta test of this new client and core, so there are likely bugs to be found as more donors try this out on more diverse sets of hardware. Also, the documentation (GPU3 FAQ) is new too and there are possibly some errors there too. However, the client has been QA'd both internally at Stanford and with our closed group of beta testers and is looking pretty good so far. Please post bugs or issues in the GPU section of this forum.
vbironchef wrote:I don't see the download for windows 7 64 bit. Could you stream line the download info for me.
Windows 7 download is the same as Vista. Just use the Vista console version.
I'm using GPU3 atm and TPF is 02:37. According to my calculations, there's a slight drop in PPD. I'll let it run a couple WU then decide whether to stick with GPU3 Beta or go back to GPU2.
Gigabyte Z77X-UD5H F14 BIOS
ASUS GTX 460 768MB @ 800/1950
Corsair AX750
Crucial M4 128GB
Western Digital Black 1TB
Cooler Master Hyper 212+ EVO
BenQ E2420HD
I AM CANADIAN!
Likewise threw it on my GTX480 (at the stock for my card of 720 core, 950 mem) and it was doing 36seconds/frame, which put it just under the hour mark.
Well, had to leave work, just looked to see if any points were turned in yet. I havent see any pop up so I'm thinking the box has locked up. Anyone else have any lockups yet?
-Thomas Jefferson
PPD seems have taken a slight hit with GPU3. Temperatures remain more or less the same though. Some users with a GTX are reporting that they don't have to hear their GPUs whine anymore with GPU3.
Not sure if it's related or not, but the core and memory speeds seem to have become a bit more important in GPU3. Or it can be the fact that these WU have a slightly different TPF when progressing through different parts of the WU.
Corsair AX750
Crucial M4 128GB
BenQ E2420HD
I AM CANADIAN!
temps and times for my GTX480 under water, this has been cranking stable since I started yesterday 530am ish (yes I know the clock on my system is off) temp steady at 46*C
-Thomas Jefferson
bubba wrote:temps and times for my GTX480 under water, this has been cranking stable since I started yesterday 530am ish (yes I know the clock on my system is off) temp steady at 46*C
How much PPD are you putting out? Can you change the Voltages?
Corsair AX750
Crucial M4 128GB
BenQ E2420HD
I AM CANADIAN!
and just heads up for us ATI users the GPU3 beta client v6.30r2 can also be used by us despite what F@H forums say but the FarCore remains the same FarCore_11 so GPU2 WU's ... but the good news is no more frigging around with switches to get your Card recognized bad news the viewer doesn't work
Asus Crosshair V Formula AMD FX 8320 @ 3700MHz NB/HT @ 2600MHZ 2x 4GB Corsair Vengeance LP 1600 C9 1x Sapphire Radeon HD 7850 9550MHz core 1250MHz mem 1x Pioneer DVD-RW DVR212S SATA 2x Samsung HD502IJ 16MB cache 7200rpm raid0 1x Samsung HD502IJ 16MB cache 7200rpm storage 1x WD2500AAJS 8MB cache 7200rpm storage Thermolab Baram1 x 120mm CM R4 90cfm 2000rpm 1x SilverStone 120mm AP 1500rpm 37.5cfm SilverStone ST75F-P 750W PSU Full Modular SilverStone RaVeN RV02B-W
