How to setup dual boot for WinVista 32bit
I have Dell XPS410 Core 2 Duo E6600. How to setup 2 windows Vista 32bit operating boot at same time, consider as Dual Boot
- dicecca112
- Site Admin
Well your a little confused or you misworded your post. You can not boot two OSes at the same time, you can only boot one at the time. Dual Boot allows you to chose at startup what OS you want to boot. So you want to Dual Boot Vista 32 bit and what other OS? You can't have two of the same Operating system to dual boot. They have to be different
Just windows Vista only, I just want to using vista on both of my hard drives. Like you running one operating system both hard drives. any suggestion how to make them work.
thank you
thank you
Why not simply access the second hard drive once Vista is installed on the first one?
What you can do is only plug one hard drive, install Vista. Unplug that drive, plug the second one. Install Vista again and then plug both drives, but I don't see the point of doing this for a single computer, especially since it's the same OS.
- dicecca112
- Site Admin
