Vista 32-bit overclocking
Operating Systems
If its an OS, its here.
nh5111
Legit User
Legit User
Post by nh5111 »
Is it even possible to overclock when using Vista? I have tried to OC without success. Nothing seems to work, is it due to the OS?
maj0r_pawnage
Re: Vista 32-bit overclocking
Post by maj0r_pawnage »
Yes it is? I think vista would have little influence over the overclocking, execpt for benchmark stability?
E6300 @ 3.51GHz 1.392v
Asus Maximus Formula
Antec 550Watt Psu
Mushkin DDR-1206@ 5-5-5-15 / 2.28v
Zalman CPU Cooler CNPS7700
6408800GTS(OC 691MHz Core/2.132GHz Mem)
2x80mm case fans +2x120mm case fans
DMB2000uk
Post by DMB2000uk »
Depends if you are trying to faux overclock using an in windows utility or doing it properly through the BIOS.
Dan
Image (<- Clickable)
tnynyn
Legit Aficionado
Legit Aficionado
Post by tnynyn »
Some medium OC here on Vista 32 no problems at all..
500w Fortron Blue Storm - DFI NF4-D (SLI & SATAII modded) - Opteron 165 @ 290x9 1.35v - 1 GB OCZ Value VX 3200 2-3-3-8 @ 230mhz - 2x 80gb Seagate SATA on Raid 0 - eVGA 8800GTS
provoko
Legit User
Legit User
Post by provoko »
Vista may be more sensitive to OCing because it's a bigger OS, but OCing should virtually be the same. Meaning, whatever's 100% stable in XP should be 100% stable in Vista. Maybe you weren't completely stable in XP.
nh5111
Legit User
Legit User
Post by nh5111 »
Actually, I never tried to OC in XP. I just upgraded a few months ago and installed full Vista 32. I have an Intel 975xbx2 mobo w/Intel Q6600. I have not been able to raise it just slightly. If I only change the FSB to go from 2.4 to 2.5 ghz it will not boot to Windows. I have tried many different ways, but nothing seems to work.
Does anyone know if I can bring it in somewhere to have it OC'd?
stopthekilling77
Post by stopthekilling77 »
check out the Intel Overclocking Guide here: http://forums.legitreviews.com/about10789.html
hope you find what you need!
Cyberpower generic case
B450M PRO-VDH MAX
Ryzen 5 3600 w/PBO/OC
CM Hyper 212 EVO push/pull
Samsung 970 EVO Plus 500GB
6GB Seagate HDD
EVGA 650BQ 650W PSU
MS LXM-00001 keyboard
werty316
Post by werty316 »
It shouldn't matter which OS you are using if you overclocking in the BIOS...
DMB2000uk
Post by DMB2000uk »
nh5111 wrote:Actually, I never tried to OC in XP. I just upgraded a few months ago and installed full Vista 32. I have an Intel 975xbx2 mobo w/Intel Q6600. I have not been able to raise it just slightly. If I only change the FSB to go from 2.4 to 2.5 ghz it will not boot to Windows.
Did you lower the memory divider first?
Dan
