How to make Window Media Player Play Flash Movies?
kellylover
Legit Little One
Legit Little One
Post by kellylover »
Hey,friends, I got some flash movies, but they don't work in my window media player. How to make they work?
Any suggestions will be appreciated.
Sparky
Re: How to make Window Media Player Play Flash Movies?
Post by Sparky »
You may be able to convert them using Super.
http://www.erightsoft.com/SUPER.html
Major_A
Post by Major_A »
Get K-Lite Codec Pack and use Media Player Classic.
http://www.filehippo.com/download_klite_codec_pack/
butterfly
Legit Little One
Legit Little One
Post by butterfly »
hi, Window media player supports avi format, so I think you should convert flash movies' format to avi first. I know a good swf to avi converter, you can find from here http://www.swftoavi.net/
maybe you can have a try, good luck.
