Bio-Hazard
Posts: 2302 Joined: Thu May 06, 2004 9:48 pm
Post
by Bio-Hazard » Mon Oct 04, 2004 11:49 am
New Socket 939 3400 at Newegg.com
Seems there is a A64 socket 939 CPU out that no one has heard of. It's listed as a 2.2 chip. But that is what the 3500 is, guess we'll just have to wait til AMD updates their spec sheets. By the core voltage it would look like it's a 130 nm chip as the 90 nm chips use a default voltage of 1.4. Things are getting a bit confussing..............
http://www.newegg.com/app/ViewProductDe ... 503&depa=0
Xerxes
Legit Fanatic
Posts: 143 Joined: Wed May 26, 2004 8:42 am
Post
by Xerxes » Wed Oct 06, 2004 9:14 am
link doesnt work and neither does a search for it
Posts: 33941 Joined: Sun Oct 05, 2003 8:45 pm
Post
by Apoptosis » Wed Oct 06, 2004 9:26 am
looks like they pulled the link down.
Bio-Hazard
Post
by Bio-Hazard » Wed Oct 06, 2004 9:30 am
Must have been a bad listing.................stuff like that does happen even to the best of companies.........................
Bio-Hazard
Post
by Bio-Hazard » Wed Oct 06, 2004 9:44 am
I just checked Newegg for socket 939 CPUs. All the new low end ones have either been taken down or sold out. Only the 3500 and above are listed.
infinitevalence
Posts: 2841 Joined: Sat Apr 24, 2004 12:40 pm
Post
by infinitevalence » Wed Oct 06, 2004 11:01 am
give them time, the chips are just hitting the channels in volume. i would give it a week or two any way just to see how peopel are doing with them.
Sovereign
Posts: 1045 Joined: Sun May 08, 2005 5:28 pm
Post
by Sovereign » Sun May 08, 2005 5:30 pm
I have one of these "phantom processors." It's 2.2GHz...512kB cache, but it has a NewCastle core instead of the Winchester core of the 3500.
CPUZ Proof...
-mogwai
Posts: 1426 Joined: Sat Apr 30, 2005 11:16 pm
Post
by -mogwai » Sun May 08, 2005 7:52 pm
yeah, i've seen it on newegg the other day. i thought "it's the same speed as the 3500... what's different here?"
OsamaBinAthlon
Legit Enthusiast
Posts: 48 Joined: Wed Oct 08, 2003 1:02 pm
Post
by OsamaBinAthlon » Sun Jul 31, 2005 7:54 pm
I think someone has made an error here - the 3400+ were a 754 pin, I can't see them going back to 3400+ with the 939's, that'd be just too confusing.
One4yu2c
Legit Aficionado
Posts: 63 Joined: Thu May 26, 2005 10:39 pm
Post
by One4yu2c » Sun Jul 31, 2005 10:42 pm
There are s939 3400+ CPUs in s939 form out there, they were just short lived. If I'm not mistaken, the only difference between it and the 3500+ was the HTT bus:
3400+ = 800MHz (1600MHz effective)
3500+ = 1000MHz (2000MHz effective)
The only 800MHz exception I know of in s939 land. It was also never released in retail form, strictly OEM.
EDIT: Typo
One4yu2c on Sun Jul 31, 2005 11:14 pm, edited 1 time in total.
Bio-Hazard
Post
by Bio-Hazard » Sun Jul 31, 2005 11:12 pm
You hit the nail on the head with that one............
You still might beablr to find them in cheap OEM systems also.
Sovereign
Post
by Sovereign » Mon Aug 01, 2005 12:36 pm
Then does my BIOS lie? I can set it to 1000MHz without issue...
infinitevalence
Post
by infinitevalence » Mon Aug 01, 2005 1:02 pm
if you do your going to be overclocking it so... hell yeah switch it to 1000
One4yu2c
Legit Aficionado
Post
by One4yu2c » Mon Aug 01, 2005 1:35 pm
infinitevalence wrote: if you do your going to be overclocking it so... hell yeah switch it to 1000
Exactly - and frankly, I'd be surprised to a see a s939 3400+ that
wouldn't hit a 1000MHz HTT.
Sovereign
Post
by Sovereign » Mon Aug 01, 2005 10:19 pm
Well I'm not OCing at the moment, does this mean that I will have a perf issue? I read over at AMD's forums about gripes with this proc needing to be set to 800MHz to boot right (mine boots OK)
