Help on clocksetting Clawhammer 3700+
LaC
Legit User
Legit User
Post by LaC »
Hi.
I've just bought the Clawhammer 3700+ socket 754, and mounted it on my Asus K8V SE DeLuxe board.
But I can't get it to work properly, as the clock is at 800, when it should be at 2400.
I've tried to set the clock in my bios settings, but the system just locks. I tried to set it at v 1.6, but the result was the same.
Aswell as when i tried different clock setting programs for windows. The system just locks as I change the cpu speed.
I have pastet in my CPUz record for information below.
Hope that somone here has a really good suggestion for me?
Regards
Lars Christensen
Denmark
From CPUZ:
CPU-Z version 1.40.5
Processors Map
Number of processors 1
Number of threads 1
Processor 0
-- Core 0
-- Thread 0
Processors Information
Processor 1 (ID = 0)
Number of cores 1
Number of threads 1 (max 1)
Name AMD Athlon 64
Codename ClawHammer
Specification AMD Engineering Sample (Engineering Sample)
Package Socket 754
CPUID F.4.A
Extended CPUID F.4
Core Stepping SH7-CG
Technology 0.13 um
Core Speed 801.1 MHz (4.0 x 200.3 MHz)
HT Link speed 801.1 MHz
Stock frequency 5000 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, x86-64
L1 Data cache 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 1024 KBytes, 16-way set associative, 64-byte line size
FID/VID Control yes
max FID 25.0x
VID range 1.550V - 1.550V
K8 Thermal sensor yes
K8 Revision ID 2.6
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
Type 02002000h
Max CPUID level 00000001h
Max CPUID ext. level 80000018h
Function eax ebx ecx edx
0x00000000 0x00000001 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00000F4A 0x00000800 0x00000000 0x078BFBFF
0x80000000 0x80000018 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00000F4A 0x00000000 0x00000000 0xE1F3FBFF
0x80000002 0x20444D41 0x69676E45 0x7265656E 0x20676E69
0x80000003 0x706D6153 0x0000656C 0x00000000 0x00000000
0x80000004 0x00000000 0x00000000 0x00000000 0x00000000
0x80000005 0xFF08FF08 0xFF20FF20 0x40020140 0x40020140
0x80000006 0x00000000 0x42004200 0x04008140 0x00000000
0x80000007 0x00000000 0x00000000 0x00000000 0x00000037
0x80000008 0x00003028 0x00000001 0x00000000 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
MSR 0x0000001B edx = 0x00000000 eax = 0xFEE00900
MSR 0xC001001E edx = 0x00000000 eax = 0x00000026
MSR 0xC0010015 edx = 0x00000000 eax = 0x00000000
MSR 0xC0010042 edx = 0x00000E0E eax = 0x002A0000
MSR 0xC0010041 edx = 0x00000001 eax = 0x00000E00
Chipset
Northbridge VIA K8T800 (VT8383) rev. 01
Southbridge VIA VT8237 rev. 00
Graphic Interface AGP
AGP Revision 3.0
AGP Transfer Rate 8x
AGP SBA supported, enabled
Memory Type DDR
Memory Size 2048 MBytes
Memory Frequency 160.2 MHz (CPU/5)
CAS# 3.0
RAS# to CAS# 3
RAS# Precharge 3
Cycle Time (tRAS) 8
Bank Cycle Time (tRC) 11
DRAM Idle Timer 16
Command Rate 1T
Memory SPD
DIMM #1
General
Memory type DDR
Manufacturer (ID) Kingston (7F98000000000000)
Size 1024 MBytes
Max bandwidth PC3200 (200 MHz)
Part number K
Serial number 530623E5
Manufacturing date Week 44/Year 05
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
Frequency (MHz) 133 166 200
CAS# 2.0 2.5 3.0
RAS# to CAS# delay 2 3 3
RAS# Precharge 2 3 3
TRAS 6 7 8
DIMM #2
General
Memory type DDR
Size 1024 MBytes
Part number K
Serial number 530624E5
Attributes
Number of banks 2
Data width 64 bits
Correction None
Registered no
Buffered no
EPP no
Timings table
CAS# 2.0 2.5 3.0
TRAS 6 7 8
Dump Module #1
0 1 2 3 4 5 6 7 8 9 A B C D E F
00 80 08 07 0D 0B 02 40 00 04 50 70 00 82 08 00 01
10 0E 04 1C 01 02 20 C0 60 70 75 75 3C 28 3C 28 80
20 60 60 40 40 00 00 00 00 00 37 46 30 28 50 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 C0
40 7F 98 00 00 00 00 00 00 00 4B 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 05 2C 53
60 06 23 E5 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Dump Module #2
60 06 24 E5 00 00 00 00 00 00 00 00 00 00 00 00 00
Monitoring
Sensor Chip Winbond W83697HF
PCI Device List
Host Bridge
bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3188
Revision ID 0x01
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xF8000000
Subvendor ID 0x1043
Subsystem ID 0x80A3
Int. Line 0x00
Int. Pin 0x00
Capabilities
AGP Capability
Offset 80h
Version 3.5
Status enabled
Transfer rate 8x (max 8x)
Queue lenght 1 (max 32)
HyperTransport Capability
Offset C0h
Revision 1.02
Interface type Slave/Primary
Link 0 width (in/out) 16 bits/16 bits
Link 0 frequency 800MHz
Link 1 width (in/out) 8 bits/8 bits
Link 1 frequency 200MHz
Power Management Capability
Offset 68h
Version 1.1
Offset 58h
Interface type Interrupt discovery and configuration
Dump
00 06 11 88 31 06 01 30 22 01 00 00 06 00 40 00 00
10 08 00 00 F8 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 A3 80
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00
40 00 19 88 80 82 44 00 00 1A B9 88 80 82 44 00 00
50 03 00 00 B1 30 2C 00 80 08 00 01 80 03 80 17 00
60 00 00 00 E0 00 00 00 00 01 58 02 00 00 00 00 00
70 C0 C8 00 01 64 3F 50 00 01 00 00 00 7F 00 00 06
80 02 C0 35 00 1A 0A 00 1F 12 03 00 00 28 00 00 00
90 00 00 00 00 30 0F 01 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 06 08 00 88
B0 40 00 11 00 88 00 00 00 A8 00 00 00 00 00 00 00
C0 08 68 60 00 20 00 11 11 D0 00 00 00 22 05 35 00
D0 02 00 35 00 00 00 00 00 00 00 22 22 32 50 22 10
E0 00 00 00 00 00 FF 19 00 00 00 00 00 00 40 00 00
F0 00 00 00 00 00 00 81 00 00 00 00 00 00 04 00 00
PCI to PCI Bridge
bus 0 (0x00), device 1 (0x01), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0xB188
Revision ID 0x00
PI 0x00
SubClass 0x04
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x01
PCI header
Primary bus 0x00
Secondary bus 0x01
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 80h
Version 1.1
Dump
00 06 11 88 B1 07 01 30 02 00 00 04 06 00 00 01 00
10 00 00 00 00 00 00 00 00 00 01 01 00 A0 A0 20 22
20 F0 FC 40 FD 80 D4 D0 F4 00 00 00 00 00 00 00 00
30 00 00 00 00 80 00 00 00 00 00 00 00 00 00 0A 00
40 91 C0 80 44 35 3A 88 B1 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 01 00 02 02 00 00 00 00 00 00 00 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
OHCI FireWire Controller
bus 0 (0x00), device 7 (0x07), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3044
Revision ID 0x80
PI 0x10
SubClass 0x00
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFD700000
Address 1 (port) 0x0000C800
Subvendor ID 0x1043
Subsystem ID 0x808A
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
Dump
00 06 11 44 30 17 01 10 02 80 10 00 0C 10 40 00 00
10 00 00 70 FD 01 C8 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 8A 80
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 20
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 01 00 02 E4 00 00 00 00 00 00 00 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Ethernet Controller
bus 0 (0x00), device 10 (0x0A), function 0 (0x00)
Common header
Vendor ID 0x11AB
Model ID 0x4320
Revision ID 0x13
PI 0x00
SubClass 0x00
BaseClass 0x02
Cache Line 0x10
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFDD00000
Address 1 (port) 0x0000C400
Subvendor ID 0x1043
Subsystem ID 0x811A
Int. Line 0x11
Int. Pin 0x01
Capabilities
Offset 48h
Version 1.1
Virtual Product Data Capability
Offset 50h
Dump
00 AB 11 20 43 17 01 B0 02 13 00 00 02 10 40 00 00
10 00 00 D0 FD 01 C4 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 1A 81
30 00 00 00 00 48 00 00 00 00 00 00 00 11 01 17 1F
40 00 00 F0 05 00 80 A0 01 01 50 02 FE 00 2E 00 0C
50 03 00 00 80 00 00 00 00 00 00 04 00 00 00 00 00
Multimedia device
bus 0 (0x00), device 13 (0x0D), function 0 (0x00)
Common header
Vendor ID 0x1131
Model ID 0x7134
Revision ID 0x01
PI 0x00
SubClass 0x80
BaseClass 0x04
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFDB00000
Subvendor ID 0x153B
Subsystem ID 0x1142
Int. Line 0x12
Int. Pin 0x01
Capabilities
Offset 40h
Version 1.0
Dump
00 31 11 34 71 06 00 90 02 01 00 80 04 00 40 00 00
10 00 00 B0 FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 3B 15 42 11
30 00 00 00 00 40 00 00 00 00 00 00 00 12 01 FF FF
40 01 00 01 06 00 60 00 FF 00 00 00 00 00 00 00 00
Audio device
bus 0 (0x00), device 14 (0x0E), function 0 (0x00)
Common header
Vendor ID 0x1412
Model ID 0x1724
Revision ID 0x01
PI 0x00
SubClass 0x01
BaseClass 0x04
Cache Line 0x00
Latency 0x40
Header 0x00
PCI header
Address 0 (port) 0x0000C000
Address 1 (port) 0x0000B800
Subvendor ID 0x3132
Subsystem ID 0x4154
Int. Line 0x13
Int. Pin 0x01
Capabilities
Offset 80h
Version 1.0
Dump
00 12 14 24 17 05 00 10 02 01 00 01 04 00 40 00 00
10 01 C0 00 00 01 B8 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 32 31 54 41
30 00 00 00 00 80 00 00 00 00 00 00 00 13 01 00 00
80 01 00 01 04 00 00 00 00 00 00 00 00 00 00 00 00
RAID Controller
bus 0 (0x00), device 15 (0x0F), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3149
Revision ID 0x80
PI 0x00
SubClass 0x04
BaseClass 0x01
Cache Line 0x00
Latency 0x40
Header 0x80
PCI header
Address 0 (port) 0x0000E800
Address 1 (port) 0x0000E400
Address 2 (port) 0x0000E000
Address 3 (port) 0x0000D800
Address 4 (port) 0x0000D400
Address 5 (port) 0x0000D000
Subvendor ID 0x1043
Subsystem ID 0x80ED
Int. Line 0x14
Int. Pin 0x02
Capabilities
Offset C0h
Version 1.1
Dump
00 06 11 49 31 05 00 90 02 80 00 04 01 00 40 80 00
10 01 E8 00 00 01 E4 00 00 01 E0 00 00 01 D8 00 00
20 01 D4 00 00 01 D0 00 00 00 00 00 00 43 10 ED 80
30 00 00 00 00 C0 00 00 00 00 00 00 00 14 02 00 00
40 23 03 F1 44 06 AF 00 00 10 82 25 03 00 00 00 00
50 00 00 00 00 00 00 04 04 00 10 10 00 05 00 10 00
60 11 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 00 00 00 01 00 01 00 00 00 00 00
80 00 00 00 00 00 00 00 00 00 00 C0 7E 00 04 C0 7E
C0 01 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 80 02 49 31 43 10 ED 80 00 00 00 00 00 00 00 00
IDE Controller
bus 0 (0x00), device 15 (0x0F), function 1 (0x01)
Common header
Vendor ID 0x1106
Model ID 0x0571
Revision ID 0x06
PI 0x8A
SubClass 0x01
BaseClass 0x01
Cache Line 0x00
Latency 0x20
Header 0x00
PCI header
Address 4 (port) 0x0000FC00
Subvendor ID 0x1043
Subsystem ID 0x80ED
Int. Line 0xFF
Int. Pin 0x01
Capabilities
Offset C0h
Version 1.1
Dump
00 06 11 71 05 05 00 90 02 06 8A 01 01 00 20 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 01 FC 00 00 00 00 00 00 00 00 00 00 43 10 ED 80
30 00 00 00 00 C0 00 00 00 00 00 00 00 FF 01 00 00
40 2B F2 09 05 18 8C C0 00 A8 20 20 20 FF 00 B6 B6
50 17 F2 F6 F1 0C 00 00 00 A8 A8 A8 A8 00 00 00 00
60 00 02 00 00 00 00 00 00 00 02 00 00 00 00 00 00
70 02 01 00 00 00 00 00 00 02 01 00 00 00 00 00 00
80 00 40 EF 7E 00 00 00 00 00 00 00 00 00 00 00 00
D0 06 00 71 05 43 10 ED 80 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 09 00 00 00 00 00 00 00 00 00
USB Controller (UHCI)
bus 0 (0x00), device 16 (0x10), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x81
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x80
PCI header
Address 4 (port) 0x0000DC00
Subvendor ID 0x1043
Subsystem ID 0x80ED
Int. Line 0x15
Int. Pin 0x01
Capabilities
Offset 80h
Version 1.1
Dump
00 06 11 38 30 15 00 10 02 81 00 03 0C 10 40 80 00
20 01 DC 00 00 00 00 00 00 00 00 00 00 43 10 ED 80
30 00 00 00 00 80 00 00 00 00 00 00 00 15 01 00 00
40 40 12 03 00 00 00 00 00 A0 0B A0 00 00 00 00 00
60 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
80 01 00 C2 FF 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00
bus 0 (0x00), device 16 (0x10), function 1 (0x01)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x81
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x80
PCI header
Address 4 (port) 0x0000EC00
Subvendor ID 0x1043
Subsystem ID 0x80ED
Int. Line 0x15
Int. Pin 0x01
Capabilities
Offset 80h
Version 1.1
Dump
20 01 EC 00 00 00 00 00 00 00 00 00 00 43 10 ED 80
bus 0 (0x00), device 16 (0x10), function 2 (0x02)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x81
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x80
PCI header
Address 4 (port) 0x0000B000
Subvendor ID 0x1043
Subsystem ID 0x80ED
Int. Line 0x15
Int. Pin 0x02
Capabilities
Offset 80h
Version 1.1
Dump
20 01 B0 00 00 00 00 00 00 00 00 00 00 43 10 ED 80
30 00 00 00 00 80 00 00 00 00 00 00 00 15 02 00 00
bus 0 (0x00), device 16 (0x10), function 3 (0x03)
Common header
Vendor ID 0x1106
Model ID 0x3038
Revision ID 0x81
PI 0x00
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x80
PCI header
Address 4 (port) 0x0000B400
Subvendor ID 0x1043
Subsystem ID 0x80ED
Int. Line 0x15
Int. Pin 0x02
Capabilities
Offset 80h
Version 1.1
Dump
20 01 B4 00 00 00 00 00 00 00 00 00 00 43 10 ED 80
40 40 12 03 00 00 00 00 00 00 0B A0 00 00 00 00 00
USB 2.0 Controller (EHCI)
bus 0 (0x00), device 16 (0x10), function 4 (0x04)
Common header
Vendor ID 0x1106
Model ID 0x3104
Revision ID 0x86
PI 0x20
SubClass 0x03
BaseClass 0x0C
Cache Line 0x10
Latency 0x40
Header 0x80
PCI header
Address 0 (memory) 0xFDA00000
Subvendor ID 0x1043
Subsystem ID 0x80ED
Int. Line 0x15
Int. Pin 0x03
Capabilities
Offset 80h
Version 1.1
Dump
00 06 11 04 31 16 00 10 02 86 20 03 0C 10 40 80 00
10 00 00 A0 FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 43 10 ED 80
30 00 00 00 00 80 00 00 00 00 00 00 00 15 03 00 00
40 00 00 03 00 00 00 00 00 80 10 00 09 00 00 00 00
50 00 5A 00 80 00 00 00 00 04 0B 66 88 33 66 66 00
60 20 20 01 00 00 00 00 00 01 00 00 00 00 00 00 C0
F0 00 00 00 00 00 00 87 00 00 00 00 00 00 00 00 00
PCI to ISA Bridge
bus 0 (0x00), device 17 (0x11), function 0 (0x00)
Common header
Vendor ID 0x1106
Model ID 0x3227
Revision ID 0x00
PI 0x00
SubClass 0x01
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x1043
Subsystem ID 0x80ED
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset C0h
Version 1.1
Dump
00 06 11 27 32 87 00 10 02 00 00 01 06 00 00 80 00
30 00 00 00 00 C0 00 00 00 00 00 00 00 00 00 00 00
40 44 00 F0 00 00 00 00 00 0C 20 00 00 44 00 08 08
50 C0 8D 09 00 00 00 00 00 43 80 00 09 00 00 04 08
60 00 00 00 00 10 00 02 04 00 00 00 00 00 00 00 00
70 43 10 ED 80 00 00 00 00 00 00 00 00 20 00 00 00
80 20 84 49 00 02 00 00 00 01 08 00 00 00 18 00 00
90 0B 00 8C 00 B0 C1 06 00 10 0C 00 00 00 00 00 00
D0 01 04 01 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 15 09 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 0 (0x00)
Common header
Vendor ID 0x1022
Model ID 0x1100
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Offset 80h
Revision 1.02
Interface type Host/Secondary
Device number 0
Dump
00 22 10 00 11 00 00 10 00 00 00 00 06 00 00 80 00
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
50 01 01 01 00 01 01 01 00 01 01 01 00 01 01 01 00
60 00 00 00 00 E4 00 00 00 0F CC 00 0F 1C 00 00 00
80 08 00 01 21 20 00 11 11 22 05 75 80 02 00 00 00
90 56 04 51 02 00 00 FF 00 07 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 1 (0x01)
Common header
Vendor ID 0x1022
Model ID 0x1101
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 01 11 00 00 00 00 00 00 00 06 00 00 80 00
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 03 00 00 00 00 00 7F 00 00 00 00 00 01 00 00 00
50 00 00 00 00 02 00 00 00 00 00 00 00 03 00 00 00
60 00 00 00 00 04 00 00 00 00 00 00 00 05 00 00 00
70 00 00 00 00 06 00 00 00 00 00 00 00 07 00 00 00
B0 03 0A 00 00 00 0B 00 00 03 00 80 00 00 FF FF 00
C0 13 10 00 00 00 F0 FF 00 00 00 00 00 00 00 00 00
E0 03 00 00 FF 00 00 00 00 00 00 00 00 00 00 00 00
Host Bridge
bus 0 (0x00), device 24 (0x18), function 2 (0x02)
Common header
Vendor ID 0x1022
Model ID 0x1102
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Dump
00 22 10 02 11 00 00 00 00 00 00 00 06 00 00 80 00
40 01 00 00 00 01 08 00 00 01 10 00 00 01 18 00 00
60 00 E6 E0 07 00 E6 E0 07 00 E6 E0 07 00 E6 E0 07
80 44 00 00 00 00 00 00 00 42 35 82 13 31 0B 00 00
90 00 8C 0C 08 07 07 7B 3E 00 00 00 00 06 01 00 00
B0 53 AE 1D EF 9C 00 00 00 C4 63 D8 05 24 FF 0B 05
D0 B2 E0 02 C1 C7 E9 58 02 8B 62 FC A9 70 01 A6 C4
E0 17 E4 03 A0 A7 6B 60 4D 52 20 FF A9 78 85 D2 27
Host Bridge
bus 0 (0x00), device 24 (0x18), function 3 (0x03)
Common header
Vendor ID 0x1022
Model ID 0x1103
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x06
Cache Line 0x00
Latency 0x00
Header 0x80
PCI header
Subvendor ID 0x0000
Subsystem ID 0x0000
Int. Line 0x00
Int. Pin 0x00
Capabilities
Secure Device Capability
Offset F0h
Dump
00 22 10 03 11 00 00 10 00 00 00 00 06 00 00 80 00
30 00 00 00 00 F0 00 00 00 00 00 00 00 00 00 00 00
40 FF 3B 00 00 40 00 40 00 00 00 00 00 00 00 00 00
60 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 11 01 02 51 11 80 00 50 00 38 00 08 1B 22 00 00
80 00 00 07 23 13 21 13 21 00 00 00 00 00 00 00 00
90 03 00 00 00 7C 00 00 00 60 1C 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 3D 00 00 00 01 F0 6B 78
D0 00 00 00 00 01 07 0D 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 4D 00 0E 07 00 00 00 00 00 00
F0 0F 00 10 40 00 00 00 00 00 00 00 00 00 00 00 00
VGA Controller
bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
Vendor ID 0x1002
Model ID 0x71C6
Revision ID 0x00
PI 0x00
SubClass 0x00
BaseClass 0x03
Cache Line 0x10
Latency 0xFF
Header 0x80
PCI header
Address 0 (memory) 0xE0000000
Address 2 (memory) 0xFD400000
Address 4 (port) 0x0000A000
Subvendor ID 0x174B
Subsystem ID 0x0850
Int. Line 0x10
Int. Pin 0x01
Capabilities
Offset 50h
Version 1.1
AGP Capability
Offset 58h
Version 3.0
Status enabled
Queue lenght 1 (max 256)
Message Signalled Interrupts Capability
Offset 80h
Dump
00 02 10 C6 71 07 01 B0 02 00 00 00 03 10 FF 80 00
10 0C 00 00 E0 00 00 00 00 04 00 40 FD 00 00 00 00
20 01 A0 00 00 00 00 00 00 00 00 00 00 4B 17 50 08
30 00 00 00 00 50 00 00 00 00 00 00 00 10 01 08 00
40 00 00 00 00 00 00 00 00 00 00 00 00 4B 17 50 08
50 01 58 02 06 00 00 00 00 02 80 30 00 1B 02 00 FF
60 12 03 00 1F 01 0D 00 00 00 00 01 11 00 00 00 00
80 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Display Controller
bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
Vendor ID 0x1002
Model ID 0x71E6
Revision ID 0x00
PI 0x00
SubClass 0x80
BaseClass 0x03
Cache Line 0x10
Latency 0x40
Header 0x00
PCI header
Address 0 (memory) 0xFD200000
Subvendor ID 0x174B
Subsystem ID 0x0851
Int. Line 0xFF
Int. Pin 0x00
Capabilities
Offset 50h
Version 1.1
Dump
00 02 10 E6 71 06 00 B0 02 00 00 80 03 10 40 00 00
10 04 00 20 FD 00 00 00 00 00 00 00 00 00 00 00 00
20 00 00 00 00 00 00 00 00 00 00 00 00 4B 17 51 08
30 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 08 00
50 01 00 02 06 00 00 00 00 02 00 30 00 1B 02 00 FF
60 00 02 00 00 01 0D 00 00 00 00 01 11 00 00 00 00
DMI
DMI BIOS
vendor American Megatrends Inc.
version 1007.003
date 06/17/2005
DMI System Information
manufacturer To Be Filled By O.E.M.
product To Be Filled By O.E.M.
version To Be Filled By O.E.M.
serial To Be Filled By O.E.M.
UUID F49DA8DC-369BD811-8E057E55-DCF7AE49
DMI Baseboard
vendor ASUSTeK Computer Inc.
model K8VSEDX
revision Rev 2.00
serial MB-1234567890
DMI System Enclosure
manufacturer Chassis Manufacture
chassis type Desktop
chassis serial Chassis Serial Number
DMI Processor
manufacturer AMD
model AMD Engineering Sample
clock speed 800.0MHz
FSB speed 200.0MHz
multiplier 4.0x
DMI Memory Controller
correction 64-bit ECC
Max module size 1024MBytes
DMI Memory Module
designation DIMM0
size 1024MBytes (double bank)
DMI Memory Module
designation DIMM1
DMI Memory Module
designation DIMM2
DMI Port Connector
designation PS/2 Mouse (internal)
designation PS/2 Mouse (external)
port type Mouse Port
connector PS/2
DMI Port Connector
designation PS/2 Keyboard (internal)
designation PS/2 Keyboard (external)
port type Keyboard Port
connector PS/2
DMI Port Connector
designation USB1 (internal)
designation USB1 (external)
port type USB
connector Access Bus (USB)
DMI Port Connector
designation USB2 (internal)
designation USB2 (external)
port type USB
DMI Port Connector
designation USB3 (internal)
designation USB3 (external)
port type USB
DMI Port Connector
designation USB4 (internal)
designation USB4 (external)
port type USB
DMI Port Connector
designation USB5 (internal)
designation USB5 (external)
port type USB
DMI Port Connector
designation USB6 (internal)
designation USB6 (external)
port type USB
DMI Port Connector
designation USB7 (internal)
designation USB7 (external)
port type USB
DMI Port Connector
designation USB8 (internal)
designation USB8 (external)
port type USB
DMI Port Connector
designation LPT1 (internal)
designation LPT 1 (external)
port type Parallel Port ECP/EPP
connector DB-25 male
DMI Port Connector
designation Audio Mic In (internal)
designation Audio Mic In (external)
port type Audio Port
connector Mini Jack (headphones)
DMI Port Connector
designation Audio Line In (internal)
designation Audio Line In (external)
DMI Port Connector
designation Audio Line Out (internal)
designation Audio Line Out (external)
DMI Port Connector
designation LAN (internal)
designation LAN (external)
port type Network Port
connector RJ-45
DMI Port Connector
designation COM 1 (internal)
designation COM 1 (external)
port type Serial Port 16550A
connector DB-9 male
DMI Port Connector
designation MIDI (internal)
designation MIDI (external)
port type MIDI Port
connector DB-15 female
DMI Port Connector
designation Joy Stick (internal)
designation Joy Stick (external)
port type Joystick Port
DMI Port Connector
designation COM 2 (internal)
designation COM 2 (external)
connector DB-9 male
DMI Port Connector
designation FireWire 1 (internal)
designation FireWire 1 (external)
port type Firewire (IEEE P1394)
connector IEEE 1394
DMI Port Connector
designation FireWire 2 (internal)
designation FireWire 2 (external)
connector IEEE 1394
DMI Port Connector
designation AUX (internal)
connector On Board Sound Input From CD-ROM
DMI Port Connector
designation CD (internal)
DMI Port Connector
designation PRI_IDE (internal)
connector On Board IDE
DMI Port Connector
designation SEC_IDE (internal)
DMI Port Connector
designation FLOPPY (internal)
connector On Board Floppy
DMI Port Connector
designation CHA_FAN (internal)
DMI Port Connector
designation CPU_FAN (internal)
DMI Port Connector
designation MAIN POWER (internal)
DMI Port Connector
designation CHASSIS (internal)
DMI Port Connector
designation ATXPWR (internal)
DMI Port Connector
designation FP_AUDIO (internal)
DMI Port Connector
designation SATA1 (internal)
DMI Port Connector
designation SATA2 (internal)
DMI Port Connector
designation PWR_FAN (internal)
DMI Port Connector
designation PRI_SATA (internal)
DMI Port Connector
designation SEC_SATA (internal)
DMI Port Connector
designation PRI_RAID (internal)
DMI Extension Slot
designation AGP
type AGP 8x
width 32 bits
populated yes
DMI Extension Slot
designation PCI1
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI2
type PCI
width 32 bits
populated no
DMI Extension Slot
designation PCI3
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI4
type PCI
width 32 bits
populated yes
DMI Extension Slot
designation PCI5
type PCI
width 32 bits
populated no
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 8192MBytes
max# of devices 3
DMI Memory Device
designation DIMM0
format DIMM
type DDR
total width 72bits
data width 64bits
size 1024MBytes
DMI Memory Device
designation DIMM1
format DIMM
type DDR
total width 72bits
data width 64bits
size 1024MBytes
DMI Memory Device
designation DIMM2
format DIMM
type unknown
Software
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition (Build 6000)
DirectX Version 10.0
Resources
Port I/O Space, BA=0xCF8, size=0x8
Memory I/O Space, BA=0x00000000F8000000
Memory I/O Space, BA=0x00000000FD700000
Port I/O Space, BA=0xC800
Memory I/O Space, BA=0x00000000FDD00000
Port I/O Space, BA=0xC400
Memory I/O Space, BA=0x00000000FDB00000
Port I/O Space, BA=0xC000
Port I/O Space, BA=0xB800
Port I/O Space, BA=0xE800
Port I/O Space, BA=0xE400
Port I/O Space, BA=0xE000
Port I/O Space, BA=0xD800
Port I/O Space, BA=0xD400
Port I/O Space, BA=0xD000
Port I/O Space, BA=0xFC00
Port I/O Space, BA=0xDC00
Port I/O Space, BA=0xEC00
Port I/O Space, BA=0xB000
Port I/O Space, BA=0xB400
Memory I/O Space, BA=0x00000000FDA00000
Memory I/O Space, BA=0x00000000E0000000
Memory I/O Space, BA=0x00000000FD400000
Port I/O Space, BA=0xA000
Memory I/O Space, BA=0x00000000FD200000
Port I/O Space, BA=0x808, size=0x4
Memory I/O Space, BA=0x00000000FEE00000, size=0x1000
Port I/O Space, BA=0x400
kenc51
Re: Help on clocksetting Clawhammer 3700+
Post by kenc51 »
It's not a problem.
Your CPU supports "cool & quiet". This means it runs @ lower speeds when idle. You can enable/disable this in the bios, and if you plan on overclocking make sure to disable it.
DMB2000uk
Post by DMB2000uk »
hmm, we don't quite need all that information there >_<
Do you have cool and quiet enabled? Try running something that will stress your CPU and keep CPU-z open to see if the CPU speed changes.
Dan
Image (<- Clickable)
LaC
Legit User
Legit User
Post by LaC »
Hi.
Thank You for the fast replys. I didn't now about how much information i s needed. I'm sorry that there was too much.
I've just rechecked, and Cool'n Quiet is off. And the cpu speed doesn't go up more than 0.01 when given high load.
I've though of possible problems:
- The bios doesn't have a multiplier, but the setting is made by choosing a frequency. But I've seen others refer that they have this cpu and MB up running, so it can't be a major cause?
- Perhaps my 400 w psu is too small? How much load will the cpu require extra when set up in speed? It did work flawlessly with my old Athlon 3000+ at stock 2000 MHz.
Regards
Lars Christensen
kenc51
Post by kenc51 »
Go back into the bios and select "load bios defaults" then exit.
After this power off the pc for ~2mins, then see it fixes it.
You can also try to reset the bios, and or update it.
werty316
Post by werty316 »
LaC
Legit User
Legit User
Post by LaC »
Hi.
kenc51 wrote:Go back into the bios and select "load bios defaults" then exit.
I tried this now. The result is the same.
kenc51 wrote:You can also try to reset the bios, and or update it.
The same result. I've tried to find a newer bios than my present one, but I haven't been lucky to find one on Asus pages. Does anyone make or use alternative bios to flash with?
Regards
Lars
DMB2000uk
Post by DMB2000uk »
Try this driver from AMD.
Dan
LaC
Legit User
Legit User
Post by LaC »
werty316 wrote:This guide should help you: http://icrontic.com/articles/overclocki ... 9_platform
Hi.
Thank You. I've been looking through these pages, and find that I might have a point regarding my PSU. The Power consumption might be higher than the delivered by my 400 watts. I've been looking at this PSU (I guess its German, as I can only find info on it in this language):
Nitrox 750W Quad-Rail Silent
ATX/ E-ATX 2.2 Netzteil AMD/Intel P4/LGA775 Dual-CPU Server fähig
750 Watt Gesamtausgangsleistung
180 Watt kombinierte Ausgangsleistung (+3,3 und +5 Volt)
432 Watt kombinierte Ausgangsleistung (+12,0 Volt)
aktive Leistungsfaktorkorrektur (PFC)
maximale Belastbarkeit der einzelnen Schienen:
+3,3 Volt: 28A
+5,0 Volt: 30A
+12 Volt: 4x 18A bzw. 12V combined 60A
There should be enough volts and ampage here?
Regards
Lars
LaC
Legit User
Legit User
Post by LaC »
Hi Dan
DMB2000uk wrote:Try this driver from AMD.
Thank You for the link. But sadly enough the file didn't work in Vista.
Lars
DMB2000uk
Post by DMB2000uk »
The power supply shouldn't be an issue with this problem.
Have you had this setup working OK on XP before? Vista could be the problem.
For total problem eliminating, try turning on CnQ in the BIOS and see if vista likes it better then.
Dan
LaC
Legit User
Legit User
Post by LaC »
DMB2000uk wrote:The power supply shouldn't be an issue with this problem.
Ok. Thank you. I'll probably save the money then. :P
No. I have been using Vista Ultimate for a month on my old Athlon 3000+, and before this for 2 Years on XP. So Vista worked with the old CPU.
I'll do this and then return.
Thank you.
Lars
LaC
Legit User
Legit User
Post by LaC »
DMB2000uk wrote:For total problem eliminating, try turning on CnQ in the BIOS and see if vista likes it better then.
Did this, but theres no change in speed. I still get 800 MHz. :?
This is really a puzzle for me.
Regards.
Lars
DMB2000uk
Post by DMB2000uk »
Well I've I no idea what's going on either :rolleyes:
Dan
kenc51
Post by kenc51 »
Vista has a C&Q driver pre-installed. Try set the power/performance profile via control panel, it could be set to maximum battery :?
LaC
Legit User
Legit User
Post by LaC »
kenc51 wrote:Vista has a C&Q driver pre-installed. Try set the power/performance profile via control panel, it could be set to maximum battery :?
Hi.
Now I've tried this. Didn't work.
But I've been googleing my problem and found out that the problem might be that its an engeneering sample. The FSB is unlocked and this doesn't work together with the Asus K8V Se DeLuxe. I've contacted the seller of the cpu, and I'm going to return the CPU.
I'll order a new one in stead that will be a mobile version of the 3700+. The only problem with this should be wether my Zalman CNPS 7700-Cu cooler will fit the mobile core. You wouldn't by chance know?
Thank You for the assistance.
Lars Christensen
infenix
Legit Little One
Legit Little One
Post by infenix »
I know this thread is old but it's so wrong I had to join and post
I have the exact same mobo and CPU: 800MHz is correct for this chip's HyperTransport FSB. It's not the CPU's processing clock (=2.4GHz). Don't worry about it. Too late now of course, cos you returned it to seller!
DMB2000uk
Post by DMB2000uk »
infenix wrote:I know this thread is old but it's so wrong I had to join and post
Does CPUz on your rig read as "Core Speed 801.1 MHz (4.0 x 200.3 MHz)" too?
Dan
infenix
Legit Little One
Legit Little One
Post by infenix »
OK,I'm back cos I made a mistake...
Just been experimentin' on my PC and had to reset the BIOS... after which My Computer Properties and CPU-Z said it was running at 800MHz! It used to say 2.4GHz.... It's many, many months since I set the thing up so I'd forgotten this stuff. :oops:
So, found the Advanced \ Jumperless Config in the BIOS and set the following settings for the CPU to make it work properly (it does now work as it should). Maybe auto settings don't work cos there're no locks on the engineering CPUs.
Core voltage 1.5v
Speed 2400MHz
The speed range is settable in the range 800-3000MHz.
*EDIT* : Forgot to mention, CPU-Z shows 2403MHz (12 x 200)
DMB2000uk
Post by DMB2000uk »
Thanks for clarifying the steps to solve this problem (even if the original poster did send the chip back).
Dan
