I have an FX-57, and I don't have that installed. Does anyone use it for their FX processor?AMD Athlon™ 64/FX Processor Driver for Windows XP and Windows Server 2003 Version (x86 and x64 exe) 1.3.2.16 - Allows the system to automatically adjust the CPU speed, voltage and power combination that match the instantaneous user performance need. Download this Setup Installation program (EXE) to automatically update all the files necessary for installation. This package is recommended for users whom desire a graphical user interface for installation. This .EXE driver is a user friendly localized software installation of the driver designed for end-users. This driver supports AMD Athlon 64/FX processors on Windows XP SP2, Windows 2003 SP1 x84 and x64 Editions.
What's this?
What's this?
-- top
Re: What's this?
It looks like the driver implementation of the Cool'n'Quiet tech.
I've installed it for a couple of friend's AMD based computers. If you aren't bothered about it trying to use less power when it is on, then I guess you don't really need it.
Dan
Dan
