Hey all, I'm looking to upgrade my cpu heatsink & fan. I'm planning on upgrading my CPU to either the x2 6000+ or the 6400+ in the next month or so.
I'd like to have one that:
...Is not overly large(i don't think my case could accomadate)
...Has LED's Blue preferably
...Must beable to hook into my rig with the default mounting hardware that comes with the crosshair ( i don't want to have to take out my mobo)
...is not too noisey
Thanks in advance.
Please see my sig for my system specs.
Lataz,
**AM2 heatsink & fan options**
System:
Lian-Li PC-A70A(blk)
Gigabyte X58A-UD3R rev1.0
i7 930 @3.5Ghz
18GB = (3x4GB Gskill)+(3x2GB Gskill) @ 1600Mhz 8-8-8-20-2n
2 x XFX 5770 1GB in x-Fire
Windows 7 Ultimate x64
500GB OS Drive WD 7200RPM 16MB Cache
Cooler Master 750Watt / Thermal Take 250Watt mini (5.25Bay)
37" 1080p LCD / 22" LCD / 19" LCD
Logitech G15
Sicuro 5.1 Surround Sound System
Novint Falcon w/Pistol Grip
Wolf King Trooper
"You must have very big rat, u need Hottori Hanzo's steel."
i7 930 @3.5Ghz
Logitech G15
Wolf King Trooper
- camaroguy1998
Re: **AM2 heatsink & fan options**
I'm using the Zalman 9700LED(Blue LED's) with the same Mobo and a 6000 x2
It comes with a fanmate controller and at low speed its not too loud!
Running Folding SMP Client it maintains upper 40'sC(100% load)
It is a bit large, you should check measurements with your case.
Corsair 4000D Airflow
