who can define Mulitple Clock Domain (MCD)
kingming
Legit Little One
Legit Little One
Post by kingming »
I heard many cases mentioning MCD. Who can give me a clear and accurate definition about it? Thanks.
Re: who can define Mulitple Clock Domain (MCD)
you mean like on Phenom processors where different areas are driven by different clock signals and you can customize some values?
AMD's Phenom has 5 clock domains, one for each core and then there is the one for the L3 cache.
