I got a 3200+ 0518 APDW and 3000+ 0516 GPAW Venice cpus just yesterday.
AMD64 3200+ 512k cache (Venice)
ADA32000DAA4BP
LBBLE 0518APDW
AMD64 3000+ 512k cache (Venice)
ADA30000DAA4BP
LBBLE 0516GPAW
Only started testing the 3200+ 0518 APDW and the memory controller ain't anywhere near as good as my 4000+ san diego (i.e. 2x512MB Gskill PC4400LE on San Diego can manage at least 300mhz 2.5-4-3-7 at 2.8v for memtest and benching, but with 3200+ Venice errors out immediately in memtest86+ v1.55.1 but still have to retest the ram properly over next few days.)
* The venice's cpu stability is even more closely tied in to memory controller/mem stability than previous winnies/clawhammer/sandy cpus I've had.
* Using my Gskill PC4400LE i had to throw out all known stable timing/settings on my other cpus and start testing from scratch with my Venice. Tref, Drive and Drive data strength can get very unstable at some settings so have to retest them all as well.
* Right now superpi 32M is fine at 2750mhz at 1.58v and stock vcore fine for up to 2550-2600mhz for pifast and 2663mhz at 1.53v.
* But memory timings play such an important part to stablize this Venice as i loosen timings further i get more stability at higher end! It's going to take alot more time to find stable mark as i have to retest from scratch Gskill PC4400LE settings then test cpu for stability.
* Different bioses gave me different stable points with cpu and ram - tried 510-2, 510-3, 414-3, 414-2 and now 310 official which seems best for cpu stability.
System
3200+ 0518 APDW water cooled
DFI NF4 SLI-D 310 official
2x eVGA 6800U PCI-E SLI 76.10
2x 512MB Gskill PC4400LE orange slots
120GB WD 1200JB
650W Silverstone SLI PSU
WinXP Pro SP2
NF4 6.53 remix chipset drivers
- note SLI mode will probably reduce cpu related performance slightly so take that into a/c with the benchmark results.
2x 512MB Gskill PC4400LE dual channel kit
@10x 266mhz 2.5-3-3-7 7-14-2-2-1-2 at 2.8v
chipset = 1.5v
LDT = 1.5v
LDT 3x
CPC = Enabled
CAS Latency(CL) = 2.5
RAS to CAS(Trcd) = 3
Min RAS# Active time(Tras) = 7
Row Precharge Time(Trp) = 3
Row Cycle Time(Trc) = 7
Row Refresh Cycle Time(Trfc) = 14
Row to Row Delay(Trrd) = 2
Write Recovery Time(Twr) = 2
Write to Read Delay(Twtr) = 1
Read to Write Delay(Trwt) = 2
Refresh Period (Tref) = 3072
Write CAS Latency(Twcl) = Auto
DRAM Bank Interleave = Enabled
Skew = AUTO
Skew Value = 0
DRAM Drive Strength = Level 3 (prior cpus 7 or 8 worked, now 1, 4, 5, 6, 7, 8 all either reboot when running pcmark04 memory test or BSOD)
DRAM Data Drive Strength = Level 1 or 2 (which allowed me to prime longer)
Max Async Latency = 7ns
Read Preamble Time = 5ns
Idle Cycle Limit = 256
Dynamic Counter = Enabled
R/W Queue Bypass = 16x
Bypass Max = 7x
32 byte Granularity = Disable(8burst)
Haven't found max yet, just trying to find a stable reference point for cpu and the ram.
Click image for larger pic
Not the best venice, but not the worst either
3200 Venice 0518 APDW + DFI NF4 SLI-D
- eva2000
2nd 3000+ Venice 0516 GPAW on 2nd DFI NF4 SLI-D
:D
System:
3000+ Venice LBBLE 0516 GPAW
Corsair Hydrocool 200 water cooled cpu
DFI NF4 SLI-D 414-3
1x eVGA 6800U PCI-E
2x512MB Gskill PC4400LE TCCD 431
160GB Seagate 7200.7 NCQ SATA on SATA3
LiteOn 48x24x48 CD burner
550W GTR 38A/12v single rail psu
WinXP PRO SP2
both systems using 6.53 remix chipset drivers
Used clockgen but didn't update cpu in MBM5
:D
System:
DFI NF4 SLI-D 414-3
1x eVGA 6800U PCI-E
WinXP PRO SP2
- infinitevalence
I have noticed the bios/ram timing limitations as well, i have been working with several people who are having a very hard time runing 1t at frequencies that were easy to hit with winchester. if you have any insight let me in because im still helping some people out.
