Overclocking a Phenom 9500
kylepaddock
Post by kylepaddock »
I was told that they are unclockable? is that true? I was thinking of getting a asus Crosshair II and OC with that?
If you have done a transaction with me, please fill out my heatware. http://www.heatware.com/eval.php?id=64039
Ebay is: horizonlongtails it is 100%!!!
Major_A
Re: Overclocking a Phenom 9500
Post by Major_A »
They don't clock very well. You are better off just buying a cheap motherboard and running it at stock. I have an original Phenom X3 and it doesn't clock worth a crap.
kylepaddock
I have it on a MSI K9N SLI v2 at the default settings. You said that you had a X3 you might like this: http://us.msi.com/landing/amd_quadcore/ ... dcore.html
stopthekilling77
Post by stopthekilling77 »
That trick only works with Phenom II x3 processors if I'm not mistaken 8-[
Cyberpower generic case
B450M PRO-VDH MAX
Ryzen 5 3600 w/PBO/OC
CM Hyper 212 EVO push/pull
Samsung 970 EVO Plus 500GB
6GB Seagate HDD
EVGA 650BQ 650W PSU
MS LXM-00001 keyboard
Major_A
Post by Major_A »
Correct and my board doesn't have the BIOS settings even if I had a Phenom II.
kylepaddock
ok, im thinking of getting these then,
http://www.newegg.com/Product/Product.a ... 6813131292 100$
http://www.newegg.com/Product/Product.a ... 6819103471 would these 2 work together?
stopthekilling77
kylepaddock wrote:would these 2 work together?
check ASUS' support site for the CPU Support List for that model motherboard, that'll answer your question 8)
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
