64bit processor problem??
- fenriswolfr
- Legit Aficionado
so I got a 4200 x2 64bit processor, and I heard of a problem with this (or maybe it the windows 64bit version) but I have to restart my computer almost every two hours (mainly when I am playing a game, such as warcraft III). Basically, everything is running smooth and fine until about 2 hrs in and then boom, the frame rate just plummets. The only way to fix it is to restart the computer. This didn't happen on my old computer (which had much worse specs) but I had the graphics settings turned all the way down. Anyhow I heard there was some problem with windows/or the processor? Is there a way to fix this?
Antec Sonata II 450W
ASUS M2N-SLI AM2 NVIDIA nForce 570 SLI
AMD Athlon 64 X2 4200+
512 Corsair DDR2 800 (will up to 2mb)
Seagate 160GB 7200 8MB SATA-300 HD
Dual layer DVD R/W drive
Geforce 6600 (for now, will up to 7900 gtx)
- fenriswolfr
- Legit Aficionado
ah ha, after digging around I found the cpu driver stuff and optimizer, it's fixed. ty
