Worthwhile upgrade?
- Legit Enthusiast
Worthwhile upgrade?
Is it worth the money to go from a 3700+ to a 4800+ X2?
MSI K8N-Neo 4F Platinum v 1.0
A64 FX-60 Dual Core @ 2.8 ghz
G-Skill 1gb x 2 PC-3200 @ 433 fsb 1t.
ASUS 6800GT Pcie @ 425/1200
DVD-RW LH-20A1L6C
DVD-RW LH-20A1L6C
- Legit User
- Legit Enthusiast
No the 3700 is running stock,mem is running at FSB216.
The 4800 I am asking about has 1mb x2 L2.
My BIOS will take up to a Opty 180,I was thinking 185 but I am not sure if it will work.
This board is not O'c friendly.
DVD-RW LH-20A1L6C
DVD-RW LH-20A1L6C
- Legit User
If this is the case, I would probably go ahead and do it. If you don't have a good OCing board, an Opty would probably not work out very well for you.CyberWarrior wrote:This board is not O'c friendly.
DFI Lanparty SLI-DR Expert
Opteron 170 (messing with OC currently)
ATI x1950 Pro PCI-e 256mb
Corsair ValueSelect 2x1gb PC3200
Westinghouse 22" Widescreen LCD
Antec NeoHE 550w
Antec NeoHE 550w
- Legit Enthusiast
- Legit Enthusiast
More Intel Core 2 Duo and Core 2 Quad processors, ATI's DX10 graphics cards and more nVidia DX10 graphics cards... a few months later will be AMD's Barcelona quad-cores.
If you will be using the same system for at minimum a year before revamping anything then yes I'd suggest switching to a X2 4800. Unless you only use your computer for light use you should quickly notice the difference a 2nd core brings.
Core i7 920 @ 4.2GHz 1.36v
Gigabyte GA-X58-UD5
Under Water
Gigabyte GA-X58-UD5
Under Water
- Legit Enthusiast
- Legit Enthusiast
Basically,some of the time I would on the web,erasing a RW on one drive and encoding a DVD on the other.So what happens is,sys just freezes and I have to cancel all tasks.I am planning on adding another 2 gigs RAM,so I think that will help a lot.
DVD-RW LH-20A1L6C
DVD-RW LH-20A1L6C
honestly, people are taking this "add more RAM" thing to extremes ;)
Normal surifng, burning, etc SHOULD NOT use the 1gb you have! You might want to check your computer for crap running that doesnt need to be.
I have 2gb on this ancient AMD 3000+ Barton, and even when video editing/encoding using Ulead programs, I still have memory available!
Mike
encoding a dvd? - ripping? burning? creating from scratch? - only creating from scratch should use masive amounts of memory.
Mike
- Legit Enthusiast
Basically I also want to move on to Vista,when all the kinks are out.
Already tried Ultimate on here with a spare drive I have,and it runs a little slow.My kid is running it on a XP 3200+ Barton with 512mb and is like working on slow motion.
DVD-RW LH-20A1L6C
DVD-RW LH-20A1L6C
Despite what they say, 512mb is not enough for Vista. Minimum specs should have been 1gb, with 2gb being best for running Vista.
The Opty 185 would be cheaper than an FX60, which have started vanishing everywhere as I think AMD no longer makes them. Opteron's were mostly favored just for the overclockability... The AMD X2 4600 probably would be your best buy since the cache difference doesn't affect most tasks. Newegg has that one for $219
Gigabyte GA-X58-UD5
Under Water
Gigabyte GA-X58-UD5
Under Water
- Legit Enthusiast
Tiger Direct has the FX-60 for $380.NewEgg has already dropped all the X2 lineup except the 4400+.
As far as the Opty 185,I could take a chance on it and hope that it runs on this board with this BIOS version.
I am just not ready to drop a ton of $$ into moving on to AM2 sys.
It reminds me of Win ME.
DVD-RW LH-20A1L6C
DVD-RW LH-20A1L6C
