What temps are dangerous for a CPU?
vicaphit
Post by vicaphit »
I have an AMD 64 3200+, I have OCed to 2.2ghtz (2ghtz stock), and it currently shows in core clock to be running at about 35C... How high do you think I could push it before I would have any chance of frying any part of my computer?
I dont want to OC any more if anything is going to get damaged, but I would like to push it a little further since it is my bottleneck.
gvblake22
Post by gvblake22 »
It isn't until you actually start getting into the upper 60ºC range that you risk doing damage to your processor. I usually try and keep my load temps at 50ºC or less so if it is an unusually hot day or something, I don't have to be too worried.
Zertz
Post by Zertz »
I think the max temperature of those chips is 70, so you want to stay below that. Personnaly, I like staying in the low 50's (full load).
gvblake22
Post by gvblake22 »
Zertz wrote:I think the max temperature of those chips is 70, so you want to stay below that. Personnaly, I like staying in the low 50's (full load).
Actually it looks like we're both right...
According to AMD's processor compare, it may very quite a bit depending on what stepping and version you have...
ADA3200DEP4AW
ADA3200DKA4CG
ADA3200DIK4BI
Zertz
Post by Zertz »
That's the exact pages I was looking for :P
vicaphit
Post by vicaphit »
and what is the best way to get it to perform under full load? should I just load up battlefield and play for a while and then quit and check temps?
has anyone ever oced one of these before? it is the orleans chip. I just want to know if there is a way to OC it higher without an awesome heatsink
the one I have is pretty large, and the intake fan is ducted to flow right past the HS (dell dimension 521)
Zertz
Post by Zertz »
ORTHOS: http://www.techpowerup.com/downloads/385/mirrors.php
It will put a 100% load on your CPU and look at your temps while it's running.
werty316
Post by werty316 »
Be sure to use CoreTemp or SpeedFan since they are more accurate.
