Thanks Apo
Your suggestion to break open my Corsair PSU and remove/shorten leads made a real difference.
Wasn't simple, but I can actually see things now.
This older Corsair 750 comes with TOOO many leads and they are REAL long (that's good and bad)
Before
After
Lead Reduction
Lead Reduction
ga-z77-dh3 (great & cheap O/C'er from Gigabyte)
i2600k/16 gigs Kingson 1600 (OC'ed to 4.5Ghz)
CoolerMaster Hyper 212 + (lapped, smok'in deal, 38C idle, 65C loaded)
MSI GTX 660ti Power Edition
Antec 900 case (quiet)
Re: Lead Reduction
Amen on the modular design.
My next PSU will be one for sure.
Dorian
Dorian
- TexasScott
- Legit Aficionado
Re: Lead Reduction
Nice job uncluttering the wires the way you did..Looks a lot lot better..Did you notice any temp changes as Im sure that gave you a little bit better airflow through the case...
I agree with Joe.....I like the modular units also....
Scott
Scott
Case:Cooler Master HAF 922
Mobo: Gigabyte 890GPA-UD3H
Cpu: AMD Phenom II X6 1055T [email protected]
Ram: G. Skill Rip Jaws-- 4gigs DDR3 1600MHz
Gpu: XFX 5870@900/1300
Psu: Silverstone 850w 80+Silver--Modular
Cooler--- Noctua NH-U12P SE2 120mm SSO CPU Cooler
Hdd----2-Samsung Spinpoint F1 320gb IN RAID0
LightScribe------dvd/cd rom player
Lamptron Fan Controller
Re: Lead Reduction
No change in temp,
leads weren't really clogging up the flow,
just got in the way of things
(imagine getting that friggin nVidia 295 brick in and out of the case)
and looked VERY unprofessional (the Antec has a nice window on the side for all to see).
- TexasScott
- Legit Aficionado
Re: Lead Reduction
Yes that must of been a Pita as it was covered over by the cables..Looks good now as you can actually see that your running a GTX 295...
Scott
Scott
- DJ Tucker
Re: Lead Reduction
congrats on getting that wire clutter sorted
MSI Z590 Gaming Edge Wifi
Corsair XR5 240mm x2 & 360mm
Corsair HX1000i
Lian Li O11D
Corsair HX1000i
Lian Li O11D
