PSU suggestions
- Legit Aficionado
PSU suggestions
What PSU do I need to get to replace the stock Bestec 300watt psu in tthis?I'll be adding another harddrive(100GB)WD and a 7600GT or 7900GS PCI-E x 16 video card.
Here's the PC:
http://www.shopping.hp.com/webapp/shopp ... aultAnchor
Here's the PC:
AMD Athlon 64 X 2 Dual-Core 3800+
Windows Media Center 2005
2GB DDR 400MHz(PC3200)Patriot sig. line ram
250GB(7200rpm,16MB cache)SATA HDD
LightScribe Dual-layer DVD+/-RW drive
9-in-1 media manager
NVIDIA GeForce 6150 LE
GPU
High Definition Audio
Corsair HX620 PSU
Logitech X530 (5.1)Surround sound subwoofer speaker system
GPU
Corsair HX620 PSU
- Legit Aficionado
Anyone?
GPU
Corsair HX620 PSU
GPU
Corsair HX620 PSU
- Legit Aficionado
Will that be adaquate enough for a 7600GT?LOL..........Should I get up the money to get one?May have to go with a 7300GTDMB2000uk wrote:You'll want a minimum of 400W, an Antec truepower or something should do nicely, or you can choose a FPS/sparkle one, they seem pretty solid too.
Dan
GPU
Corsair HX620 PSU
GPU
Corsair HX620 PSU
lets just say that nvidia reccommends a 400W PSU for a 7900 card, so it will be more than adequate for a 7600/7300. If you are that tight for cash, you could get the 7600GT and say a 350W PSU (dont know if that works out similar price or not), but if you are gaming I would really reccommend the 7600 (even GS) over the 7300 if you can somehow stretch to that much.
Did your relative not end up giving you that seasonic PSU?
Dan
Dan
- Legit Aficionado
He sold it to buy some damn crack
GPU
Corsair HX620 PSU
GPU
Corsair HX620 PSU
My favorite PS of all time is the Silverstone Strider 400. It was $45(on sale) and is beautifully made (very high quality inside)
I had 4 HDDs and 2 7600GS vidreo cards and never had a problem
http://www.svcompucycle.com/sst-40f-41.html
I am 24% addicted to Counterstrike. What about you?
Biostar 590/AMD 6400+
2 Gigs of Ballistix Tracers
2 WD 160Gig in Raid0
8800GTs in SLI
PC Power & Cooling 510(highly modified)
Case Changes Weekly, lol
8800GTs in SLI
- Legit Aficionado
Anybody kmow where I can find the dimensions of the PC Power & Cooling PSU's?I've been searching.
GPU
Corsair HX620 PSU
GPU
Corsair HX620 PSU
8800GTs in SLI
8800GTs in SLI
- Legit Aficionado
Okay,thanks it's just what I needed.
GPU
Corsair HX620 PSU
GPU
Corsair HX620 PSU
