@ Hi Tech Legion"The Mugen 3 PC Games Hardware Edition CPU Cooler is a new take on Scythe’s top of the line cooler. The Scythe Mugen 3 PCGH Edition replaces the single variable speed fan with two 120mm Slip Stream fans running at 800rpm capable of 40.17cfm each, in a push/pull configuration. The Mugen 3’s design is a natural for dual fans, as it features a “Multiple Airflow Pass-Through Structure” with channels creating far less resistance for air between the two fans. This multiple tower design also greatly improves efficiency, allowing for lower rpm fans to provide better than expected cooling and, just as importantly, quiet cooling. The Mugen 3 features aluminum fins with six copper heat pipes capped off with polished aluminum ornamental nuts. This presents the Mugen 3 with a very hi-tech, industrial look. The base plate is nickel plated copper and is polished to a mirror finish, with only the slightest hint of milling marks. "
Tuesday Web Reviews:
HARDWARE
Cooler Master Notepal X-Slim Notebook Cooler Review @ Neoseeker
Western Digital Caviar Green 3TB Hard Drive Review @ eTeknix.com
Hanjung Grip100-S and Grip110-U2 Notebook Cooling Pads Review
Antec Solo II Case @ Rbmods
Fostering Better Heatsinks - Does Zalman really use Composite Heatpipes?
Events
NVIDIA GeForce LAN 6 October 14-16 2011 Coverage @ Hi Tech Legion
Electronics
Samsung Galaxy Fit Review @ Tech-Reviews.co.uk
Games
Mad Catz Street Fighter X Tekken Arcade FightStick Pro @ BmR
