Sata II with ATA100?
I have 2 hard drives, a 250 gb SataII Seagate Barracuda with 16mb cache and a WD Caviar 120 gb ATA100 w/8 mb cache. When both are hooked in my machine it says that the seagate is operating in ATA100 mode. Does this affect performance at all? My computer seems to boot faster with only the seagate hooked up. Unless I'm just imagining things?
- CoolerMaster Elite 330
- Gigabyte GA-P35-DS3L
- 4 GB G-Skill DDR2 800
- Antec Trio TruePower 650w
Re: Sata II with ATA100?
I don't think it should downgrade your performance, since you still got 100 Mb/s and my raid 0 system with two WD500 got a burst speed of about 130 Mb/s, so one drive should definetly be under 100 Mb/s.
My seagate gets a burst speed about 90mb. So I guess it should be fine then. Thanks man!
A utility called HD tune. Its freeware so you can google it.
Does rpm speeds on the hard drive make a difference on the HD Tune benchmarks? Because I have a sata150 WD 10K RPM 74GB and a 2x Raptor sata150s RAID 0 and I got some pretty nice burst speeds. Both were around 120MB. I'm just wondering because if you have a sata2 drive, I'd figured the MB transfer would be much better.
-- top
Yes, I would assume the rpm speed would matter in a speed test.
