HELP with RAID
nayaseedq
Legit Little One
Legit Little One
HELP with RAID
Post by nayaseedq »
My PC has following
Epox EP-5EPA+ Motherboard with Intel® Matrix RAID Technology
Intel Pentium 4 540 Prescott 800MHz FSB LGA 775
Two Maxtor MaXLine III SATA Hard drives 300GB each.
I stalled WinXP and then i realized i did nothing to setup RAID.
My current Rwrite speed is 58.5 Mbytes/sec, but i heard i could get as good as 200 to 250 MB/Sec with Raid0 is that true?
I need that because i do lot of video processing.
Since already installed my OS, how can i setup the RAID0 now? My total space is 300+300 GB, will i be left with only 300GB if i apply Raid0.
Please help me with Raid0 setup , ?????
infinitevalence
Post by infinitevalence »
nope the best you might do is 100mbs and thats still only burst speed. generally your not going to get any improvement in applications that dont NEED lots of bandwidth. if your doing video editing then you might want to think about it but 54mb is more than enough for video editing. you also need to remember that raid0 means that if either drive fails you loose ALL your data.
kenc51
Post by kenc51 »
Welcome nayaseedq!
As infinitevalence said... you will NOT see any real world benefit! Some people setup raid 0 for their program files folder.. But even then...Games etc. only load 3-4 seconds quicker if your lucky!
Video editing only needs about ~35mb/sec to be SURE you don't drop any frames..even if you work with HD content. (a fast 5700rpm drive will do)
Raid 0 = 2x the chance of data loss...
I personally think RAID on desktops is just a gimick... Unless you have IMPORTANT data -> then setup RAID 1 (but if it's that important..then backup to another pc or dvd?)
just keep that second 300Gb drive for a working folder for your files...if you keep your large vid files on a seperate drive you WILL get better performance (things will "feel" smoother)
sbohdan
Post by sbohdan »
actually when you convert video files the best is if you place the temporary file on the other drive then where the source video is and the final output folder on the same HDD as the source is. this way when converting the source reading and temporary files writing is done by 2 separate drives instead on the same drive (ex. C drive reading and D drive writing instead of drive C reading and writing at the same time) this will speed up the conversion.
Main rig: NZXT Phantom modded case with Danger Den WC, Gigabyte B550 Aorus Elite, Ryzen 5800X @ stock, 32GB Patriot Viper DDR4 3200Mhz 16-18-18-36-1T, AMD RX 5700XT + AlphaCool WC, ACER Nitro XV2 27", SP 1TB nvme PCiE GEN3, Samsung 2TB; Cooler Master MW Gold 650W, Win10 Pro 64
kenc51
Post by kenc51 »
sbohdan wrote:actually when you convert video files the best is if you place the temporary file on the other drive then where the source video is and the final output folder on the same HDD as the source is. this way when converting the source reading and temporary files writing is done by 2 separate drives instead on the same drive (ex. C drive reading and D drive writing instead of drive C reading and writing at the same time) this will speed up the conversion.
thats why I said keep the second drive as a working folder - i wasn't clear enough.. sorry
infinitevalence
it is true that you will actualy see more of an improvement in graphics, and video if you use the second drive as a scratch driver and keep your data on the other drive.
sbohdan
Post by sbohdan »
kenc51 wrote: thats why I said keep the second drive as a working folder - i wasn't clear enough.. sorry
yeah... I usually try to be more specific assuming the other party doesn't know everything that we take for granted. If he does, than its OK. if he doesn't then I helped.
nayaseedq
Legit Little One
Legit Little One
Thanks a lot
Post by nayaseedq »
Thanks a lot for the advice.
Man!, i should have taken advice first here before i bought those 2 SATA drives replacing my IDE's.I guess i fell into trap of RAID and SATA, now i realize even from other forums that SATA & RAID r just a waste of money like camera cell phones.
infinitevalence
not always some times its worth it, when i was doing video editing and i only had 2 160gb drives i used raid because it gave me enough space to work. and you still have two drives and 600gb of storage so its not all bad.
