Been A While!
- DJ Tucker
Been A While!
Hello everyone. sorry i been away for so long but i been a busy man. anyway i'm back with a question. With my 9800gt sli setup in my sig what single 400 and 500 series nvidia card card would perform on par and what benchmarks if any can so the proof?
MSI Z590 Gaming Edge Wifi
Corsair XR5 240mm x2 & 360mm
Corsair HX1000i
Lian Li O11D
Corsair HX1000i
Lian Li O11D
Re: Been A While!
Maybe this will help. A GTS 250 is basically a higher clocked 9800 GT. You might have to Google around to find your answer. Here's a list of nVidia cards and each card's specs.
http://www.hardwaresecrets.com/article/ ... -Table/132
- DJ Tucker
Re: Been A While!
thx major. thats makes it easier to find instead of having many IE's open at once. so from this i can see that my 9800gt setup is between the 450 and 460 SE. so anything above that will give me a performance boost. On looking at that chart the 460 1GB 336 cores will give me about another 9800gt performance but will have 1gb not 512mb to play with and the benchmarks i have found prove this
Corsair HX1000i
Lian Li O11D
Corsair HX1000i
Lian Li O11D
