PRODUCT DESCRIPTION
The new Dremel Trio Tool System offers a versatile and effective multi-function system. With 360 degree cutting technology and plunge-cut ability, Trio makes quick and controlled cuts in wood, plastic, drywall, metal, and wall tile. With sanding and routing capability, Trio will take your project from start to finish! The Trio is an approachable, versatile tool that can cut, sand, and rout. Typical to the Dremel brand the versatility of the tool does not end there the new Dremel Trio Tool System is complete with a full line of accessories and attachments to tackle countless projects in and around the home. Includes: Trio Tool, TR607 (1/2 in. Sanding Mandrel and assorted sanding bands), TR563(Hard Wood/Sheet Metal Bit, Carbide), TR654(Straight Router Bit), TR800 (Circle/Straight Edge Guide), Wrench, Collet, and Case.
Variable speed with a maximum of 20,000 RPM so you can set the speed to match the accessory attachment and the project
90 Degree pivoting handle and multiple grip zones for comfortable, versatile handling
Plunge cut capability and 360 degree cutting technology eliminate the need for pilot drilling and the need to stop cutting for turning corners
Versatile tool cuts, sands and routs a variety of materials
Combination spiral jigsaw, edge sander and detail router for your convenience
Lightweight and compact for maneuverability
Includes the Trio tool, a 1/2 in. sanding mandrel, assorted sanding bands, a hard-wood and sheet-metal bit, a straight-router bit, a circle- and straight-edge guide, a wrench, a collet and a case
MFG Brand Name : Dremel
MFG Model # : 6800-01
MFG Part # : 6800-01
Dremel Trio Tool Kit for $40 Shipped + taxes
- Apoptosis
- Site Admin
HomeDepot.com has Dremel Trio Tool Kit (6800-01) for $39.97 with free shipping.
