Dell 1501 laptop
Dell 1501 laptop
So I just want to know if any one has had the same issue I'm having with dell. I got a dell 1501 laptop on Friday and all was ok I took a low end laptop as I did not have a lot of money to spend on a better one. ok so issue I'm having with dell right now. The lap top is suppose to have a 1150 chip set but I got one with a 200m chip set that is not even offered by dell, so i call dell and they are not open weekends but I did get some support from them in the tech support department what turns out he can understand me or does not want to. I give the info and they are going to get back to me Monday with what is going on. So if you have a dell 1501 check to make sure you have the 1150 with 256 hypermem as this one only has 128 and is not a 1150.
