HIS 5850
HIS 5850
i have a HIS 5850 video card.i recently experienced an increase in temperature .ok bear with me.i think its because i changed my stock cpu cooler to a corsair h50,and what was once an exaust fan is now an intake for the corsair radiator.i wouldnt worry about it normally,but it went from 29 c to around 38c,and when im gaming it gets up to 50c.are these safe temps?any feed back is greatly appreciated, rock on.im not slamming his,but this card cost more than my cpu and i dont want to fry it .
Re: HIS 5850
dont worry until it hits over 80C, with load under 60C you should consider yourself lucky
-Austin
Screamin' BCLK:
Screamin' BCLK:
Re: HIS 5850
i think im just greedy.i did some more research on it and i guess it was due to the fact that i built this rig during the winter.this is my first home made pc.does having your h50 with 2 fans make a signifigant diffrence?skier wrote:dont worry until it hits over 80C, with load under 60C you should consider yourself lucky
Re: HIS 5850
yes
-Austin
Screamin' BCLK:
Screamin' BCLK:
- TexasScott
- Legit Aficionado
Re: HIS 5850
Your temps are great as far as the 5850 goes...Running 2 fans(push pull) on the Corsair H50 makes a difference in temps especially if you turn it around and made it your exhaust and not your intake...But sense your temps seem to be fine no sense in messing with it.....If its not broke,dont fix it...chrhadden wrote:i think im just greedy.i did some more research on it and i guess it was due to the fact that i built this rig during the winter.this is my first home made pc.does having your h50 with 2 fans make a signifigant diffrence?skier wrote:dont worry until it hits over 80C, with load under 60C you should consider yourself lucky
How are your cpu temps?Just curious...
Scott
Case:Cooler Master HAF 922
Mobo: Gigabyte 890GPA-UD3H
Cpu: AMD Phenom II X6 1055T [email protected]
Ram: G. Skill Rip Jaws-- 4gigs DDR3 1600MHz
Gpu: XFX 5870@900/1300
Psu: Silverstone 850w 80+Silver--Modular
Cooler--- Noctua NH-U12P SE2 120mm SSO CPU Cooler
Hdd----2-Samsung Spinpoint F1 320gb IN RAID0
LightScribe------dvd/cd rom player
Lamptron Fan Controller
Re: HIS 5850
they stay between 31 c and 38c,unless i run prime 95 then they get up to 45c or so.TexasScott wrote:Your temps are great as far as the 5850 goes...Running 2 fans(push pull) on the Corsair H50 makes a difference in temps especially if you turn it around and made it your exhaust and not your intake...But sense your temps seem to be fine no sense in messing with it.....If its not broke,dont fix it...chrhadden wrote:i think im just greedy.i did some more research on it and i guess it was due to the fact that i built this rig during the winter.this is my first home made pc.does having your h50 with 2 fans make a signifigant diffrence?skier wrote:dont worry until it hits over 80C, with load under 60C you should consider yourself lucky
Scott
Re: HIS 5850
Temps seem fine.
If you are itching to do something and have an unused fanslot you can always throw in a couple $10 fans. Or get a case with a side mounted fan like my Antec 300 to cool off the card.
Core i7 2600k/ ASUS P8Z68-V Z68/ 8gb Corsair Vengeance 1600 Blue/ EVGA Geforce GTX 560ti Maximum Graphics Edition/Windows 7/Antec 300/Antec 650w/LG Blu Combo/Hp 27inch 2710M/Samsung P2770HD
"I think sharing is overrated...and helping others. And what's all this crap I've been hearing about tolerance?"
Re: HIS 5850
well is that typical?im gonna put another fan on my h50 no matter what but what kind of temps are you getting?
Re: HIS 5850
well this case has an 8 in fan thats pointed right at my cpu and vga.its an azza case and it was only 50 bucks.thx for your input btw.it gets pretty hot and humid here in delaware.i guess im just tripping.i have an amd 555 be,i was able to unlock 1 core to make it a 3 core cpu,then i over clocked it ,i was hoping to get 4.0gigs out of it.it runs well at 3.7.i can feel it screaming at me to back off though lolSttm wrote:Temps seem fine.
Re: HIS 5850
i suggest that should buy a VGA cooler that is really good and has the fast RPM.
Re: HIS 5850
CPU temps below 40C are great and so are GPU temps below 70, you dont need to do anything
-Austin
Screamin' BCLK:
Screamin' BCLK:
Re: HIS 5850
In that case I suggest a $100-150 room air conditioner. Helps with CPU temps, and keeps you from sitting in ball soup.chrhadden wrote:well this case has an 8 in fan thats pointed right at my cpu and vga.its an azza case and it was only 50 bucks.thx for your input btw.it gets pretty hot and humid here in delaware.i guess im just tripping.i have an amd 555 be,i was able to unlock 1 core to make it a 3 core cpu,then i over clocked it ,i was hoping to get 4.0gigs out of it.it runs well at 3.7.i can feel it screaming at me to back off though lolSttm wrote:Temps seem fine.
Re: HIS 5850
thats to damn funny
Re: HIS 5850
i just set mine up that way and it did make a difference.my cpu now runs at 28c.and my gpu runs at about 50c.it probably has alot to do with the heat wave we have here.skier wrote:yes
