SourceDailyTech has received early benchmarks of ATI’s upcoming Radeon X1950XTX and X1950 CrossFire graphics cards. ATI’s
upcoming Radeon X1950XTX and X1950 CrossFire is expected to make its debut on August 23rd. Specifications for the Radeon X1950XTX and X1950 CrossFire are finalized with a 650 MHz core clock and 2 GHz effective memory clock. The core clock is unchanged from the previous Radeon
X1900XTX while memory clock receives a hefty 550 MHz boost. This time around the Radeon X1950XTX and X1950 CrossFire are equipped with 90nm Samsung GDDR4 memory.
The benchmarks compare ATI’s Radeon X1950XT in CrossFire against NVIDIA’s Quad SLI. The test setup used for NVIDIA’s Quad SLI is a Dell XPS 700 system equipped with an Intel Core 2 Extreme X6800, 1GB of
DDR2-800 memory and two GeForce 7950GX2 graphics cards for four total GPUs. The ATI CrossFire test system is identical with the Quad SLI system except the nForce 590 SLI Intel Edition motherboard was swapped out for an early Radeon Xpress 3200 (RD600) motherboard and two ATI Radeon X1950XTX/CrossFire graphics cards.
These early benchmarks are favorable to ATI. Call of Duty 2, Half-Life 2: Episode 1 and Serious Sam II heavily favor ATI, most likely due to better multi-GPU scaling on ATI’s side. FarCry, Quake 4 and Doom 3 performance shows the Quad SLI system creeping up to the performance of ATI’s X1950XTX/CrossFire system. However, the Quad SLI system still falls behind, close but no cigar. F.E.A.R. is the only game that can take advantage of Quad SLI and shows the Quad SLI system beating out the
similarly configured X1950XTX/CrossFire system; though at 2560x1600 with 4xAA and 8xAF the X1950XTX/CrossFire takes the lead once again.
With Elder Scrolls IV: Oblivion the X1950XTX/CrossFire system manages to take a nice lead over Quad SLI at 1600x1200 with 8xAF. The lead narrows when the resolution is raised to 2560x1600 with 8xAF.
While these early benchmarks show ATI’s X1950XTX/CrossFire beating out NVIDIA’s Quad SLI there’s more to the story. Since the benchmarks are only comparing performance with 4x anti-aliasing and 8x anisotropic filtering at most, it doesn’t show the true performance of NVIDIA’s Quad SLI. The true performance of Quad SLI being its capability to render highlevels of anti-aliasing without taking a heavy performance hit.
ATI X1950XTX Takes NVIDIA 7950GX2 Quad-SLI
- Apoptosis
- Site Admin
- Dragon_Cooler
- infinitevalence
Those were faked, at least according to what I hear at [H]ardForum...
Play
Work
Work
- kenc51
the GX2 card can't be fully utilised in games(yet)......it does give more 3d mark socres, but less FPS compaired to the new ATI card.......
The GX2 card is more complicated and has less mem bandwidth..........with todays hi-end cards memory bandwidth is where it's at IMO
See here
http://www.vr-zone.com/?i=3885
Ken
See here
Ken
Are there any other reviews of this card to support what VR-Zone has to say?
Play
Work
Work
Isn't it to clarify, x1950xtx and a x1950 crossfire card vs two dual cored gfx's? so its 2 cards vs 2 cards just 2 gpus vs 4 gpus. It makes me glad to see ati still competing with nvidia. However I agree with most that we can't afford this kind of performance if only they could just find a way to cut costs on all of this stuff.
