I just got 3 x 1GB of these by FexEx, from 4 All Memory, today and installed them:
Information SPD EEPROM (A0) :
Manufacturer : Samsung
Part Number : M3 78T2953EZ3-CF7
Serial Number : 8130726F
Type : DDR2-SDRAM PC2-6400 (399 MHz) - [DDR2-800]
Format : Regular UDIMM (133.35 x 3)
Size : 1024 MB (2 ranks, 4 banks)
Module Buffered : No
Module Registered : No
Module SLi Ready (EPP) : No
Width : 64-bit
Error Correction Capability : No
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 1.8v
Prefetch Buffer : 4-bit
Manufacture : Week 47 of 2007
Supported Frequencies : 333 MHz, 400 MHz
CAS Latency (tCL) : 4 clocks @333 MHz, 5 clocks @400 MHz
RAS to CAS (tRCD) : 5 clocks @333 MHz, 6 clocks @400 MHz
RAS Precharge (tRP) : 5 clocks @333 MHz, 6 clocks @400 MHz
Cycle Time (tRAS) : 15 clocks @333 MHz, 18 clocks @400 MHz
Min TRC : 20 clocks @333 MHz, 24 clocks @400 MHz
Copy and Pasted the info from PC Wizard 2008.
But I really have no idea what all the numbers mean, stuff like 'Supported Frequencies" how can you tell which one its using? And stuff like 4 clocks, 5 clocks etc are greek to me.
I just plugged the three sticks in and didn't even attempt to mess with BIOS or anything. Did I do it right?
Thanks for any help you can give.
Okies, just found this info off of CPU-Z:
DRAM Frequency: 384.1Mhz
FSB: DRAM: CPU/6
CAS# Latency (CL) 6.0 clocks
RAS# to CAS# Delay(tRCD) 6 clocks
RAS# Precharge (tRP) 6 clocks
Cycle Time (tRAS) 18 clocks
Bank Cycle Time (tRC) 25 clocks
Command Rate (CR) 2T
Hope someone can figure out what all this means
MEMORY Question: help a gal figure this out
eMachines T5010 desktop, modified with Asus M2NPV-VM motherboard, AMD Athlon 64x2 4400+ dual core processors @ 2.3GHZ, 3GB Samsung DDR2-SDRAM PC-6400 (399Mhz)-[DDR2-800], 420 Watt PSU, Windows XP Home Edition and XFX GeForce 8600GT XXX (1/17/08).
Re: MEMORY Question: help a gal figure this out
Seems to be running a LITTLE slower than the 399 or 400 it should be at - yours is showing 384.1.
try running cpu-z again and see if the speed has come up any, if you would
You did good - most memory you can just pop in and go - unless you overclock or want to set tighter timings (I never wanted to), you are good to go.
Mike
Mike
- dicecca112
- Site Admin
probably speedstep or a program reading error. Nothing to worry about
- kenc51
It's because the AM2 4400+ has a 1/2 multiplier (10.5)
The AMD memory controller underclocks the ram slightly when any 1/2 multi is used.
they pretty much answered the question. But, for future reference. If you want help. And you can't get any from people online. All you do is say help a gal. Or Cute girl needs help.. I will keep that in mind. Altho I'm a guy so what no one knows. Maybe my sn should be different lol
girls, guys, doesnt matter to me - I just happened to be on looking at the response to my question at the time.
I am married, so if they dont have nekked pictures with em, I dont really care
Mike
Mike
Thanks to everyone for responding Now I know everything cool and I don't have to puzzle myself with those zillions of numbers, I just enjoy the gaming. Thanks again!
