Bought the following combination for my primary build….. F2-8500CL5D-2GBPK / Kuma 7750 BE / Asus M3A78-CM. With the three together no matter what I do there is no boot/start/run/whatever.
However the following will work:
1. The PC2-8500 / Brisbane 4000+ / -CM will boot and run.
2. F2-6400PHU2-2GBHK / 7750BE / -CM and not only boots but I’ve managed to overclock the 7750BE to 3.187GHz stable with the 6400 memory set to 2.1V 677-4-4-4-12-2T.
3. The PC2-8500 / Opty 1210 / Abit nf-m2 nView motherboard combination overclocks very well. The memory has allowed me to run a stable 3.1+GHz.
Also the memory has run several passes of memtest without errors.
SO does this mean that the memory and processor are not compatible??
F2-8500CL5D-2GBPK / Kuma 7750BE / Asus M3A78-CM Issues
- jedihobbit
- Legit Fanatic
DreamCatcher v4.0 DOA >> SG01 Evo, TA790GXE, PII X4 945 (AQ H2O Cooled), BFG GTX280 H2OC, Seagate 7200.10 ST380815AS 80GB, 2 x WD5000KSs, TWIN2X4096-8500C5DF, MODU82+ EMD525AWT, XP Home SP2
Kermit v4.0 VIRUSed >> Ultra MX6, 785GM-E65, PII X4 955 @ 3.70GHZ(air), XFX GTX285, Raptor X, F3-12800CL7D-2GBPI, OCZ700MXSP ModXStream Pro, XP Home SP2
Oz1a v2.0 >> XFX MDA72P7509 750a, PI X2 8870BE @ 3.00GHZ(air), 2 x XFX GTS250, WD 250GB, F2-8500CL5D-2GBPK, Tt TR2 600W, XP Pro SP3
- stopthekilling77
Re: F2-8500CL5D-2GBPK / Kuma 7750BE / Asus M3A78-CM Issues
I would check ASUS' site for their memory compatibility chart for that motherboard. If they're on that list then I would email ASUS support and see what they have to say.
Cyberpower generic case
B450M PRO-VDH MAX
Ryzen 5 3600 w/PBO/OC
CM Hyper 212 EVO push/pull
Samsung 970 EVO Plus 500GB
6GB Seagate HDD
EVGA 650BQ 650W PSU
MS LXM-00001 keyboard
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
- jedihobbit
- Legit Fanatic
Sadly Asus's compatibility info is almost a year old and not very incourgeing....they only list intel boards! However it will run on the -CM, just not with the 7750BE. NOt sure if I'm missing some little item in the bios or not.
- stopthekilling77
Worst case scenario I'd say you might want to sell that RAM and use the kind you know works with that CPU
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
B450M PRO-VDH MAX
6GB Seagate HDD
EVGA 650BQ 650W PSU
- jedihobbit
- Legit Fanatic
Oddly enough I'm using it in a system whose PC2-6400 I stole and is helping me get a stable 3.15GHz out of my Opty 1210 (1.8GHz stk). Only issue is that it is recognized as PC2-6400!
Meanwhile the F2-6400PHU2-2GBHK is helping me get stable 3.187GHz out of the Kuma
- jedihobbit
- Legit Fanatic
