Hi,
can anyone tell me if it is ok to run a ATI x1950pro in an asus A8NSLI Deluxe and any issues that may be associated with running ati hardware in Nvidia motherboards. I am only running a single card so the sli bit should not enter into the equation i hope
asus a8nsli deluxe
asus a8nsli deluxe
C2Q Q6600 @ 3.60Ghz
temps 36 idle 62 load
vcore 1.3375v bios 1.312v cpuz
Asus P5-KC-P35
pny8800gt 256meg Freezer7 pro
Etasis ET750w Quad Rail
4x1gig pc8500 OCZ2N1066SR2G@800 5-5-5-15 2t 2.1v
200Gig maxtor Sata
Aspire X-Infinity case
XP Pro SP3
Asus P5-KC-P35
200Gig maxtor Sata
XP Pro SP3
Re: asus a8nsli deluxe
You can run an ATI video card on a nVida motherboard and vice-versa with a nVidia video card on an ATI motherboard.
Only limitation is Crossfire is not support on a nVidia SLI motheboard and vice-versa on with SLI on a ATI Crossfire board.
I know that is what sucks about it. I just wish that they could have worked out a standard for dual video cards so that you could run either setup on any chipset.werty316 wrote:Only limitation is Crossfire is not support on a nVidia SLI motheboard and vice-versa on with SLI on a ATI Crossfire board.
A Dual GPU standard would have been pretty cool, like a lot of things in a PC; SATA, RAM, PCI etc. Aside from the obvious marketing, i imagine the chipsets would play a large part in Crossfire and SLI.
For the original poster, i would say get an NVIDIA card if your buying a new one, may as well at least have the option of adding a second card later on, with a single ATi card that is obviously not an option. If, however you already had the card or you got it from a friend or something then that's a different story.
AMD Athlon 64 x2 3800 @ 2.7Ghz
Asus A8N32-SLI Deluxe
eVGA 8800GTS 640MB SuperClocked
A-Data 2GB DDR400
Integrated Sound
Hiper Type-M 580W PSU
A-Data 2GB DDR400
Integrated Sound
