Hi all.
I am having some overclocking issues after updating bios to latest 2813.
I have a Q6600, BX2 and 4 x 1 GB DDR2 800 ..
I used to do whatever clock i wanted, really... but after the update i can
ONLY boot stock. I cant step a single mhz. OR boot 1:1 ..
The errortype i get is when i try to OC it will either boot black screen or say POST error on the screen press "Y" to enter bios.
(i havent tried disable watchdog yet. Will try tonight.)
Best regards
Lasse.
D975XBX2 OVERCLOCK PROBLEM! BIOS 2813
- Legit Enthusiast
Re: D975XBX2 OVERCLOCK PROBLEM! BIOS 2813
Replied to your email. Let me know if you got it fixed!
- Motherboard: Intel 975XBX2 - CPU: Q6600 - Cooling: Zalman 9500 - GPU: EVGA 8800GT SC 512MB - OS: Windows Vista Ultimate 64 Bit - PSU: OCZ Gamexstream 700W - Case: TT Armor VA80000SWA - RAM: PI Black G.SKILL DDR2 6400 4GB Kit 2 x 2GB -
Check out my rig at http://www.evga.com/community/ModsRigs/ ... sysid=6091
Disable watchdog.
Life is short and dinnertime is chancy
Eat desert first!
Eat desert first!
- Sparky
Yep, watchdog is most likely preventing your successful OC. Move your mobo jumper over to post, boot disable watchdog, shut down, move jumper and then try some OCing. Good luck.
Hi guys.
Thanks a lot for the feedback. Watchdog did the trick! I am so happy now, i just dont ever recall to disable it in ANY other bios version!?
But it works like at charm now! ..
Q6600 QUAD running @ 2925 mhz FSB @ 1300 mhz DDR2 @ 810mhz.
That
That
