Help choosing a mother board
- Legit User
These are specs of my new rig:
CPU: Intel Core2 Duo E6400 2.13Ghz
Graphic Card: ATI Radeon X1900 XT 256MB or Nvidia GeForce 7900GT
HD: Sata2
I plan on overclocking my CPU to 2.4 Ghz, does anyone have any recommendations on a good mother board that supports this and is not extreamly expensive
Also which Graphic card do u think i chould choose with that.
Thx in advance
HD: Sata2
Thx in advance
- kenc51
GIGABYTE GA-965P-S3 865 chipiset $115
This is prolly the best bang for buck Core 2 motherboard......It can overclock well too. Obviously if you pay more for a motherboard, the better it should OC.
With your CPU you will want to run a high FSB to get some nice clocks......but the above board should do well from what I've read.
What's your budget?
What's your budget?
- dicecca112
- Site Admin
7900GT or x1950Pro Pro is a little faster than the 7900gt and it is about 249$ at newegg.
I recommend the P5B-E or P5B (160ish and 150)
http://www.zipzoomfly.com/jsp/ProductDe ... ode=247113
http://www.zipzoomfly.com/jsp/ProductDe ... ode=247083
Sapphire x1950pro at newegg for $199.99 That's a steal
http://www.newegg.com/Product/Product.a ... 6814102061
- Legit User
- dicecca112
- Site Admin
your not gonna find anything but the P5B-E for under 200. As for the sound its onboard sound, its good not great. I don't use it, I use a M-Audio Revolution Card. But its more than capable of delivering good sound. P5B-E can hit 500FSB with the right cooling and whatnot, so you could possibly hit 4GHZ on that C2D with the right cooling etc. I'm using the P5B-E that you can see, I've not pushed my 6400 but on stock volts I'm hitting 2950, 3 isn't perfectly stable.
- Legit User
- dicecca112
- Site Admin
yeah it does. It can only set the ram voltage to 2.2. But if you get this team group, you can easily hit 500MHZ on it way below 2.2volts on the ram.
This ram runs stock 400mhz at 1.8volts http://www.tankguys.biz/2x512mb-44410-8 ... def192dd5a
its what I run. 162$ for 512MB x 2.
- Legit User
- kenc51
The XMS memory can run with lower latencies and will overclock betterlinkinparkks wrote:i kinda prefer to just buy it at a store, got lots of kingston and Crossair memorys here, could you recommend me one coz there's so many models and what are the differences between the XMS, kit, and the VS models for the Crossair memories
thx, sorry for asking so much
The XMS2 6400C4 should do well.....
- dicecca112
- Site Admin
- dicecca112
- Site Admin
